View Full Version : pulling trans
stoveguyy
02-04-11, 02:59 PM
never seen a trans dropped out the bottom on a newer GM FWD car. in most cases the subframe is lowered. than trans is separated from motor? so motor is supported from above? does motor have to be lowered a bit to pull trans bellhousing away from motor?
stoveguyy
02-05-11, 11:05 PM
checked alldata today. trans removal procedure is about what i thought. support motor. remove subframe. pull trans.
