94CaddyConcours
09-28-04, 10:21 PM
When I use my OBD1 I can overwrite things on there but i dont know what the code mean.
Also when I check the OBD on what my gas octan rating it read zero. I always use 91 octane. What could be the problem?
-BILL SONG
-AOL SCREEN NAME: khm3rkaliking
Eldyfig
09-28-04, 11:29 PM
The octane rating doesn't work on mine either. I have read somewhere that some OBDI cars aren't equipped with that capability
oldgamer
09-29-04, 04:03 PM
On my 94' STS gas octan read zero too. :annoyed:
I believe, when they designed PCM, they designed it for years ahead and not all the options now are used.
caddyshack24
09-29-04, 05:33 PM
ive got the sensor in my 1993 STS and it works :)
Whether you get a readout and what the value is, are dependent on several things, one of which is the horsepower rating. If you have the LD8 (270) HP engine it will always read 0 (zero). See attached image for better explanation.
-George
oldgamer
09-30-04, 09:59 AM
I've got 295hp engine on 94' STS with Z-rated tires (if it's depends of it some how) and it still reads 0. I think I should check some settings after I changed PCM. It has same service number like my old one, but that PCM has been pull out from Deville.
JSMeloche
09-30-04, 10:08 AM
where did you found what the outputs mean?!? i have a GM manual and it doest say anything about the meaning of all the outputs.
