View Full Version : sealing washers for the water bridge
fast68
01-29-11, 01:14 PM
ok i been looking at threads the last couple days here because we are working on a 98 catera due to major oil leak at the oil cooler banjo bolt seals
well we found the seals for those but could not locate the sealing washers for the water bridge bolts
the dealer wants 200 bucks for them as a kit only
so fail there...
i was then at a total loss and scratching my head.. until today.. after finding FJC-4062 and 12992647 part numbers for these... in which both lead directly to dead ends... even with napa interchange attempts
i finally went on the napa online site and searched for sealing washers myself..
and i got:
A/C Comp Manifold Sealing Washer
Product Line: NAPA Temp Products
and then called napa back again and had them look up ones that are 15.5mm ID, or close to it and it turns out they have a whole bunch of 15.2mm ID ones on the shelf
finally found them wow...
that was a major PITA..
these sealing washers are used on a/c compressors
hope this helps someone...
it sure was real fun figuring out...
wow..
now we can finally put this thing back together...
RippyPartsDept
01-29-11, 02:03 PM
read up here http://www.cadillacforums.com/forums/cadillac-catera-cimarron-forum/210339-oil-my-coolant.html#post2361649
#12992647 $9.50 x4 (coolant cross-over seals - these are the ones that are only for 00-05 L-series and 03-04 vues and 03-04 cts -- on the catera they want you to buy a new cross-over design that comes with the seals but you can just get these seals) #40 in the 2nd illustration
RippyPartsDept
01-29-11, 02:10 PM
oh, i see you updated your post.... and you found the correct part number too... nice
the kit is a whole new crossover with seals etc and that's why it's so expensive
fast68
01-29-11, 06:29 PM
yeah these GM numbers dont work for this '98 though.... and that kit for 200 bucks yeah i about fell off this chair when they told me that one... wow dumb..
the washer GM part number comes up as nothing at Napa and at our delaer here... no good at either place.....
it crosses over to nothing valid.,... so i dont know..
FJC-4062 is the other number but wont cross at Napa either
i had to totally find these washers from scratch with no valid numbers or anything else i didnt know know the proper name of these either...
but i got it figured out
the Napa 407275 in the TEM line are the ones that work great and are same size ID anyways
6 bucks for four of them
so...
there is no other way to get these washers around here, in the same day anyways
anyways just posting this as an available and easy and cheap option and way to get these sealing washers locally and quickly
for those who have a dealer that is worthless and no other way to locally or quickly find any that work.
so you can look them up seperately without the kit, for a 2000?? but not for a 98??
wtf? really?
dumb..
RippyPartsDept
01-29-11, 07:16 PM
i think the part number i gave you may be a replacement seal for the new cross-over (in the kit that you don't want to buy) ... if you are certain that part number is not the same as on your original seals then this is probably the case ... i'm certain they have their reason(s) for the redesign
retho78
01-31-11, 08:24 PM
If you go to my post "Anti freeze leak. Need help" you maybe able to find some more information.
Thanks
