View Full Version : Got a new set of headers for mine 425
gornati
01-18-11, 07:06 AM
Hi all, long time i am not posting in here, but since i left my car in the shop to repair a few thing, a lot of other thing were found and its been 2 months and the car is still in the shop and probably will not leave for the next 2 months.
I first decided to fix a exhaust leak on the exhaust manifold, what we tought was just a blown gasket became a huge problem, began with the small problem that the manifold bolts were rusted and they had to remove the engine to remove the bolts.
-To remove the engine, they had to disassemble the front suspension, now the surprises:
1. all 4 balljoints were bad;
2. all 8 bushing for the A-ARMS desintegrated as soon as they removed them;
3. there was no pad left in the brake pads;
4. the small hoses for the calipers were leaking;
5. the calipers needed a rebuild kit;
6. mastercilinder could not be rebuild;
7. brakebooster was bad and they cannot rebuild that in Brasil;
8. Engine mounts were damaged;
9. small leaks in the oil pan gasket;
10. Radiator upper hose was about to blow
11. valve covers were rusted
12. tie rod ends were damaged
13. stabilizer bar links were damaged
14. LH coil was broken
15. front colis were cut with a torch, DAMAGED
16. Engine expansion plugs were starting to rot.
**** 17. MANIFOLD HAD A CRACK, CANNOT BE WELD..
Based on all that, i decided to fix those things, i ordered those from ROCKAUTO:
1978 CADILLAC DEVILLE 7.0L 425cid V8 TBI (T) OHV
ACDELCO18K265 (http://wiki.rockauto.com/1978%20CADILLAC%20DEVILLE%207.0L%20425cid%20V8%20T BI%20%28T%29%20OHV_Caliper%20Repair%20Kit_1025479_ 1720)Caliper Repair Kit (http://www.rockauto.com/catalog/raframecatalog.php?carcode=1025479&parttype=1720)$ 3.08$ 0.002$ 6.16
ANCHOR2387 (http://wiki.rockauto.com/1978%20CADILLAC%20DEVILLE%207.0L%20425cid%20V8%20T BI%20%28T%29%20OHV_Motor%20Mount_1025479_5552)Moto r Mount (http://www.rockauto.com/catalog/raframecatalog.php?carcode=1025479&parttype=5552)$ 4.60$ 0.002$ 9.20
DAYCO70860 (http://wiki.rockauto.com/1978%20CADILLAC%20DEVILLE%207.0L%20425cid%20V8%20T BI%20%28T%29%20OHV_Radiator%20Upper%20Hose_1025479 _2058)Radiator Upper Hose (http://www.rockauto.com/catalog/raframecatalog.php?carcode=1025479&parttype=2058)$ 12.81$ 0.001$ 12.81
DORMAND35937 (http://wiki.rockauto.com/1978%20CADILLAC%20DEVILLE%207.0L%20425cid%20V8%20T BI%20%28T%29%20OHV_Caliper%20Repair%20Kit_1025479_ 1720)Caliper Repair Kit (http://www.rockauto.com/catalog/raframecatalog.php?carcode=1025479&parttype=1720)$ 5.02$ 0.002$ 10.04
FEL-PRORDS55029 (http://wiki.rockauto.com/1978%20CADILLAC%20DEVILLE%207.0L%20425cid%20V8%20T BI%20%28T%29%20OHV_Axle%20Housing%20Cover%20Gasket _1025479_10630)Axle Housing Cover Gasket (http://www.rockauto.com/catalog/raframecatalog.php?carcode=1025479&parttype=10630)$ 3.27$ 0.001$ 3.27
FEL-PROOS30202C (http://wiki.rockauto.com/1978%20CADILLAC%20DEVILLE%207.0L%20425cid%20V8%20T BI%20%28T%29%20OHV_Oil%20Pan%20Gasket_1025479_5436 )Oil Pan Gasket (http://www.rockauto.com/catalog/raframecatalog.php?carcode=1025479&parttype=5436)$ 11.53$ 0.001$ 11.53
FEL-PROVS50032R (http://wiki.rockauto.com/1978%20CADILLAC%20DEVILLE%207.0L%20425cid%20V8%20T BI%20%28T%29%20OHV_Valve%20Cover%20Gasket_1025479_ 10710)Valve Cover Gasket (http://www.rockauto.com/catalog/raframecatalog.php?carcode=1025479&parttype=10710)$ 15.43$ 0.001$ 15.43
FEL-PRO35043 (http://wiki.rockauto.com/1978%20CADILLAC%20DEVILLE%207.0L%20425cid%20V8%20T BI%20%28T%29%20OHV_Water%20Pump%20Gasket_1025479_2 148)Water Pump Gasket (http://www.rockauto.com/catalog/raframecatalog.php?carcode=1025479&parttype=2148)$ 1.32$ 0.001$ 1.32
FEL-PRORDS550281 (RDS55028-1) (http://wiki.rockauto.com/1978%20CADILLAC%20DEVILLE%207.0L%20425cid%20V8%20T BI%20%28T%29%20OHV_Axle%20Housing%20Cover%20Gasket _1025479_10630)Axle Housing Cover Gasket (http://www.rockauto.com/catalog/raframecatalog.php?carcode=1025479&parttype=10630)$ 2.40$ 0.001$ 2.40 FEL-PROTCS45011 (http://wiki.rockauto.com/1978%20CADILLAC%20DEVILLE%207.0L%20425cid%20V8%20T BI%20%28T%29%20OHV_Timing%20Cover%20Gasket%20Set_1 025479_5484)Timing Cover Gasket Set (http://www.rockauto.com/catalog/raframecatalog.php?carcode=1025479&parttype=5484)$ 15.71$ 0.001$ 15.71
MEVOTECHMES2020RLT (http://wiki.rockauto.com/1978%20CADILLAC%20DEVILLE%207.0L%20425cid%20V8%20T BI%20%28T%29%20OHV_Tie%20Rod%20End_1025479_7428)Ti e Rod End (http://www.rockauto.com/catalog/raframecatalog.php?carcode=1025479&parttype=7428)$ 8.07$ 0.002$ 16.14
MEVOTECHMK6630 (http://wiki.rockauto.com/1978%20CADILLAC%20DEVILLE%207.0L%20425cid%20V8%20T BI%20%28T%29%20OHV_Stabilizer%20Bar%20Link_1025479 _7580)Stabilizer Bar Link (http://www.rockauto.com/catalog/raframecatalog.php?carcode=1025479&parttype=7580)$ 5.54$ 0.002$ 11.08
MEVOTECHMK6145T (http://wiki.rockauto.com/1978%20CADILLAC%20DEVILLE%207.0L%20425cid%20V8%20T BI%20%28T%29%20OHV_Ball%20Joint_1025479_10070)Ball Joint (http://www.rockauto.com/catalog/raframecatalog.php?carcode=1025479&parttype=10070)$ 9.36$ 0.002$ 18.72
MEVOTECHMES2019RLT (http://wiki.rockauto.com/1978%20CADILLAC%20DEVILLE%207.0L%20425cid%20V8%20T BI%20%28T%29%20OHV_Tie%20Rod%20End_1025479_7428)Ti e Rod End (http://www.rockauto.com/catalog/raframecatalog.php?carcode=1025479&parttype=7428)$ 7.22$ 0.002$ 14.44
MEVOTECHMK6144 (http://wiki.rockauto.com/1978%20CADILLAC%20DEVILLE%207.0L%20425cid%20V8%20T BI%20%28T%29%20OHV_Control%20Arm%20Bushing_1025479 _7532)Control Arm Bushing (http://www.rockauto.com/catalog/raframecatalog.php?carcode=1025479&parttype=7532)$ 5.54$ 0.004$ 22.16
MEVOTECHMK5208 (http://wiki.rockauto.com/1978%20CADILLAC%20DEVILLE%207.0L%20425cid%20V8%20T BI%20%28T%29%20OHV_Ball%20Joint_1025479_10070)Ball Joint (http://www.rockauto.com/catalog/raframecatalog.php?carcode=1025479&parttype=10070)$ 8.47$ 0.002$ 16.94
MEVOTECHMK6109 (http://wiki.rockauto.com/1978%20CADILLAC%20DEVILLE%207.0L%20425cid%20V8%20T BI%20%28T%29%20OHV_Control%20Arm%20Bushing_1025479 _7532)Control Arm Bushing (http://www.rockauto.com/catalog/raframecatalog.php?carcode=1025479&parttype=7532)$ 7.72$ 0.004$ 30.88
ROCKWELLRC5426 (http://wiki.rockauto.com/1978%20CADILLAC%20DEVILLE%207.0L%20425cid%20V8%20T BI%20%28T%29%20OHV_Coil%20Spring_1025479_7512)Coil Spring (http://www.rockauto.com/catalog/raframecatalog.php?carcode=1025479&parttype=7512)$ 90.79$ 0.001$ 90.79
ROCKWELLRV611 (http://wiki.rockauto.com/1978%20CADILLAC%20DEVILLE%207.0L%20425cid%20V8%20T BI%20%28T%29%20OHV_Coil%20Spring_1025479_7512)Coil Spring (http://www.rockauto.com/catalog/raframecatalog.php?carcode=1025479&parttype=7512)$ 73.79$ 0.001$ 73.79
SEALED POWER3818004 (http://wiki.rockauto.com/1978%20CADILLAC%20DEVILLE%207.0L%20425cid%20V8%20T BI%20%28T%29%20OHV_Expansion%20Plug_1025479_5332)E xpansion Plug (http://www.rockauto.com/catalog/raframecatalog.php?carcode=1025479&parttype=5332)$ 16.31$ 0.001$ 16.31
TRWHB1634 (http://wiki.rockauto.com/1978%20CADILLAC%20DEVILLE%207.0L%20425cid%20V8%20T BI%20%28T%29%20OHV_Stabilizer%20Bar%20Bushing_1025 479_7624)Stabilizer Bar Bushing (http://www.rockauto.com/catalog/raframecatalog.php?carcode=1025479&parttype=7624) $ 1.71$ 0.002$ 3.42
WAGNERZD52 (http://wiki.rockauto.com/1978%20CADILLAC%20DEVILLE%207.0L%20425cid%20V8%20T BI%20%28T%29%20OHV_Brake%20Pad_1025479_1684)Brake Pad (http://www.rockauto.com/catalog/raframecatalog.php?carcode=1025479&parttype=1684)$ 15.72$ 0.001$ 15.72
DAYCO70861 (http://wiki.rockauto.com/1978%20CADILLAC%20FLEETWOOD%207.0L%20425cid%20V8%2 04BBL%20%28S%29%20OHV_Radiator%20Lower%20Hose_1026 650_2057)Radiator Lower Hose (http://www.rockauto.com/catalog/raframecatalog.php?carcode=1026650&parttype=2057)$ 10.71$ 0.001$ 10.71
And then ordered those from EBAY:
http://img835.imageshack.us/img835/9247/cdlvmkkgrhqjjqe0d4sfn6p.jpg
and those:
http://img840.imageshack.us/img840/3486/cbhkt4wb2kkgrhqfiee0eub.jpg
Well, the question is, have anyone ever ordered those headers im showing here?
I will be receiving those in 2 weeks, because i am from Brasil, and i am very curious and would like to be 100% sure that they will fit just fine.
Would i have any improvements?
Remembering that my car already have a 2.5" exhaust system with a single flowmaster, i am going to go stainless stell all the way from the headers with dual flowmasters.
With all those fixes, car should be just like new, i forgot to mention, that timing chain is new and sprockets are new and they are not plastic, flywheel is new, torque converter is brand new, also car is FUEL INJECTED, all 8 injectors are flowing equally and with new seal and everything.
i will post some pictures of the car in the shop later today.
I US DOLLARS the shop is charging me about $1200.00 to do all the fixes, plus i spent $450 in parts, plus $260 in the headers plus $20 in the valve covers, bringing a total of $1980.00.
They painted the engine to match the OG color included on the price.
gornati
01-18-11, 07:23 AM
those are some crappy pictures i took on the shop.
http://img232.imageshack.us/img232/5007/img20101222101629.jpg
http://img822.imageshack.us/img822/5149/img20101222101616.jpg
http://img200.imageshack.us/img200/7027/img20101222101535.jpg
http://img441.imageshack.us/img441/381/img20101222101527.jpg
http://img59.imageshack.us/img59/7528/img20101222101402.jpg
http://img683.imageshack.us/img683/7556/img20101222101350.jpg
gornati
01-18-11, 07:55 AM
forgot to mention, 8 bolts broke inside the block, so they had drill them and make new females...
deVille33
01-18-11, 11:08 AM
Well one thing that bothers me is the fact that they had to remove the steering and suspension to remove the engine. Doesn't make sense in my mind. You remove the engine by lifting it out of the engine compartment, with the crossover disconnected from the manifolds. Why didn't they just pull the heads and repair the broken bolts? Then you would only have the extra cost of the head gaskets.
It is difficult to determine if those headers will work on that engine, as the clearance between the exhaust ports and the upper control arm mounts are very close. The collector is in the center and by eyeballing it to my car suggests the left side may fit, but the right side would be tight to the frame cross section and the motor mount. If you buy them and they work, Hurrah! If they don't your out some bucks. I think these headers are for a rat rod conversion, not a stock application. If you can determine who the manufacturer is, you can make an inquirey as to whether they may fit a stock application.
deVille33
01-18-11, 11:27 AM
Those are not tuned headers. You may have some gains performance-wise due to a less restrictive manifold, but not because they are performance headers.
The fact that your control arm bushings are worn is not surprising, as those bushings are very small. Cadillac did that to aid in clearancing the control arms to the exhaust manifolds. The weight of the front end and the heat from the exhaust cause deterioration of the rubber. I would recommend replacing the bushings with urethane bushings, which stand up better to pressure and heat.
deVille33
01-18-11, 11:30 AM
Send me detailed pics of your brake booster. I may have one for replacemant.
gornati
01-18-11, 11:31 AM
i agree with you, but im glad that i done the whole thing, now i have brand new suspension, (shocks are ok), brakes etc...
I contacted the seller on ebay, and they told me, they fit fine on the 76 deville, probably will fit nice in the 78. lets wait and see.
i will keep you posted.
I remeber some time ago, a user from the forum got those exact same headers, i just could not find the topic.
deVille33
01-18-11, 11:43 AM
'76 deVille has a wider stance and more room around the engine than the '77 - '79s. I wish you well with your endeavors and if they work it would be good info for me to stuff into my data banks.
gornati
01-18-11, 11:54 AM
well, im confident it will fit.. .i will let you guys know
gornati
01-19-11, 06:32 AM
Hey Deville, i appreciate your help i already got one off ROCKAUTO dot com..
its is in the car already.
Thanks
cadillac_al
01-25-11, 07:33 AM
Another classic Caddy revived from near death; good job Gornati. Thos headers should fit. I think those type of headers are made for tight clearances. They will definitely look better. I like the dark blue paint on the block; it looks like the old Cadillac blue. I thought all the 78's had the corporate baby blue. I painted over a dark blue 76 block last year and I have been kicking myself ever since. I should have ordered the correct classy blue. Since yours is a 78 the baby blue would be correct but I would go with the older blue if I was being detail oriented. Keep us posted on your progress. You should get a lot of enjoyment out of that car.
gornati
01-25-11, 07:51 AM
thanks, on those pictures the block is not painted yet...
they will try to match the baby blue.
i purchased the headers, just waiting for the usps deliver it in brasil.
i will keep you guys posted.
bicentennialcadillac
01-29-11, 09:41 PM
This car is in good hands - hope you get her on the road soon!
gornati
01-30-11, 03:35 PM
thanks!!!
soon it will be on the streets!
deVille33
01-31-11, 09:10 AM
Did the headers fit?
gornati
02-01-11, 07:13 AM
they are still stuck in customs...
probably will receive them in 4-5 days.
73super
02-02-11, 08:05 AM
Rock Auto.. man I'm glad they're around. Absolutely the best value for those looking for parts. I've used them over and over again and have always been happy.. PRAISE BE THE ROCK!
Side Note: I'm rather new to this website.. but do we have to have those annoying little commercials next to EVERYTHING we reply to? Whatever.
gornati
02-02-11, 11:24 AM
if you dont want the ads, just pay the site...
73super
02-02-11, 02:39 PM
Pay the site? I have that option? I guess I need to read some of the fine print.
thx... I didn't know.
BRUCE ROE
02-05-11, 09:18 PM
If those headers really added a LOT of performance, you might need a little more fuel from that fuel injection. But just having a low restriction exhaust can make quite a difference without retuning. Bruce Roe
gornati
02-07-11, 05:33 AM
i have 2.5" all the way with flowmasters Bruce.
