: Installing new cap/rotor (LT1) where do I buy the torx socket to remove the screws?
01-13-11, 09:59 PM
Tried to remove the Dist. cap on the 96 FWB today and got stuck when it came to removing the torx screws on the cap. I know the size is #4 but the socket I bought from AutoZone was too short for the right side screw, it removed the left side. AutoZone was the only store around that even carried that size. Where else should I shop for the proper tool?
01-14-11, 01:11 PM
Do you have a Harbor Freight Tools near you? I'd check there.
01-14-11, 05:54 PM
I was selling the correct GM elongated ones
may have 1 left..
01-15-11, 10:04 PM
I had the same problem with the socket being too short... I just ground it down on a bench grinder to give it the reach it needed...
