: Need help with rear view mirror options
2005ESCALADEOWNER
01-01-11, 10:21 PM
I recently purchased a 2005 escalade. The rear view mirror has several options on it, including onstar, passenger airbag toggle, compass and termperature. May be more, i can't remember. None of the options work. It's like there's no power to the mirror. I've looked and can't see that any fuses are bad but i'm very amateur in my diagnostics. Any ideas on what i might check?
2005ESCALADEOWNER
01-05-11, 12:58 PM
All these views and no suggestions? Some of my radio lights and some of the steering wheel button lights don't work either but the buttons work fine.
nathanjax
01-05-11, 03:14 PM
No idea on the mirror. But the steering wheel buttons and radio lights are common with ALL gm vehicles as well as a/c control lights/buttons.
http://www.cadillacforums.com/forums/cadillac-escalade-ext-esv-forum-1999/174367-some-steering-wheel-lights-out.html
Nathan
Stuff I'm selling. PM me or email nathanandkatiec@gmail.com
Lowering Torsion Keys 1" to 3" Lower - $40
Bilstein HD Front Shocks #F4-BE5-6500-H0 - $80
Bilstein HD Rear Shocks #F4-BE5-6501-H0 - $100
Belltech Rear Shock Extenders #6651 - $50
DJM 3/4" Urethane Rear Bump Stops #10S - $10
Eibach Front & Rear Sway Bars #3882.320 - $200
McGaughy's 2" Drop Spindles #33004 - $200
SPC Camber Bushings 86350 (total of 4, 2 for each side) - NEW - $70
AIR LIFT 1000 Series Rear Air Spring Helper Bag Kit #60769 with Belltech 5" Rear Coil Springs #5305 - $200
Factory Ipod Interface PAC #PAC-GMC2 - $90
Factory Video Interface PAC #VCI-GM2 -$200
Platinum Escalade A/C Vents $150
roboteacher
01-05-11, 09:44 PM
simple solution. there's a connector that controls all the power under plastic cover. I removed it to grab 12 VDC and mistakenly removed the wire. hopefully yours is just as simple
