: Oil in coolant, 4.5
8eldorado8
01-01-11, 12:32 PM
I recently bought a 1988 Eldorado 4.5.The car has 102000 and the body is in mint condition. The water pump recently went and I replaced it. A lot of the coolant was drained and replaced. After running a few errands I checked the overflow resivoir and it was black. I stuck a screw driver to the bottom and there was a crud that looked like wet brown sugar on it when I pulled it out.
After closely examining the engine I saw that both valve covers had brand new gaskets meaning there was some kind of recent work done on the engine. My question is, is this because recent engine work was done and the cooling system was maybe never flushed could this have stirred up because of replacing the water pump? If there is an actual problem what do I need to look into intake leak, head gasket?
The car runs perfectly fine as in temperature, idling, driving, heater works. Any help is greatly appreciated.
HUF
01-02-11, 01:24 AM
How thick was the layer of crud? It could be GM-recommended old coolant additive (Bar's Leaks Gold powder). Head gasket failures are very rare on 4.* engines. If you do not know when the coolant was replaced, you might want to do that. Put Bar's Leaks Golden powder stuff into the radiator neck. You can buy it in tubes at Wal-Mart for a less than two dollars. One tube will be enough.
drewsdeville
01-02-11, 01:49 AM
Er, I respectfully disagree. I myself have done 3 4.X headgasket jobs. Aluminum block under cast iron heads makes for some abnormal thermal expansion and contraction that tears up the headgaskets, just like the intake gaskets.
creeker
01-02-11, 02:55 PM
If it was my car I would clean out the overflow tank, maybe some one put the bars leak into it instead of the radiator, you probably dont even need to add more bars leak,
especially if you dont drain cooling system.
creeker
01-02-11, 04:23 PM
I just thought, if it was oil in overflow tank, it would be floating on top of water, not laying in bottom of tank, so it's good news that it's probably bars leak.
the recluse
01-03-11, 08:40 PM
^^^^Agreed. It could be sediment from the cooling system itself (little to no coolant equals rusty water and sediment). Either way, sediment on the BOTTOM is better than oil on the TOP.
Flush the system vigorously, back, forth, front, to back. If there is that much sediment in the reservoir, than the radiator must be a mess...
