: Looking to buy an STS, asking for some guidance
Darkshear
12-28-10, 01:13 AM
Hello everyone,
I'm in the market for an 05-06 STS. After reading a bit here and there, I learned about the options packages. I love the N*, so that is a must for me. Navi, XM, and moon roof also. SO, I understand 1SF meets those requirements. But, what is 1SG? I know it's like "The works", but what makes it so different? I pulled RPO codes for a few VINs I was looking at, and the 1SG is hard to find it seems. But the power assist steering seems interesting, so I've accumulated a few questions for you guys, I hope I'm not imposing too much....
What are the differences between 1SF and 1SG?
Are there any known issues that would be considered serious on the RWD N* platform?
What is the difference between 3.23 and 3.42 ratios? Which would be best?
It seems impossible to find ACC and HUD... Is this a 1SG exclusive?
Can I visually tell the difference between a 1SF and a 1SG by the pictures?
The power assist steering, is it more trouble than it's worth? BMWs is obnoxious, how about this?
From what I have been able to assemble, I really want a 05 or 06 1SG, red on black or black on black. Apparently, this combo is hard to find with 1SG. Also, trying to get it for under 15k, but that seems to be the easy part.
I found ONE car in California that meets this stuff. Looks clean, but it has the factory chrome 18's on it, and apparently a 3.42:1 final drive? Should I care?
1SG seems to have the adaptive steering, but I can't see any other difference other than "cooling upgrade"? What is that?
Should I give a damn about a 1SG versus a 1SF?
Thanks in advance guys, I appreciate any time you take to help me out.
M.A.C
12-28-10, 01:39 AM
May advice is that you buy an AWD (All Wheel Drive) STS. The RWD is not good in rain or snow. My next STS will definitely be AWD. I hope a few with AWD will chime in and confirm this.
Darkshear
12-28-10, 01:44 AM
I wouldn't mind the AWD version, I would love it in fact. But I live in FL so I'm not worried about the snow, and hopefully traction control would take care of most of my rain problems....but most of all, I can't even imagine how hard it would be to find an AWD 1SG black or red on black.....
rzambrano
12-28-10, 02:10 AM
http://cgi.ebay.com/ebaymotors/Cadillac-STS-RWD-w-1SG-2008-CADILLAC-STS-PERFORMANCE-1SG-PACKAGE-BLACK-_W0QQcmdZViewItemQQhashZitem483e3d9c28QQitemZ31028 1870376QQptZUSQ5fCarsQ5fTrucks#ht_11381wt_1167
Darkshear
12-28-10, 09:20 AM
Nice car, but it's about ten grand more than I'm looking to burn.
Loren
12-28-10, 10:07 AM
Here ya go, hope what you are looking for is here.........
http://www.cadillacforums.com/forums/cadillac-sts-forum-2005-through-2010/197257-those-1sa-1sb-1sc-1sd-1sf.html
tomm
12-28-10, 08:30 PM
Hello everyone,
Where are you located? I am on the east coast and plan on putting my 2005 up for sale soon to get an Escalade since my family is outgrowing the STS? Your wish list sounded like my wish list when I was shopping for one and it took me a few months to find exactly what I wanted. Mine has everything and still less than 50K miles original sticker was $68k but I will want more than $15k for it. At my last oil change the dealer offered me $17k
My suggestion to you is if you want HUD & ACC you can find them but you will have to be patient and you might have to shop around for a while but its worth it. They are my favorite features on my STS. There is nothing like ACC on the highway. You set the speed and it takes care of everything for you. If someone cuts in front of you it will automatically apply the brakes and keep you at your set distance from the car in front of you. If the car in front speeds up or moves out of the lane it will accelerate for you to bring you back up to speed.
EChas3
12-28-10, 09:10 PM
I am not certain ACC can be had on less than a 1SG. I also think the 3:42 rear-end-gear is exclusive to the AWD, but I don't think you want or need that low a gear & AWD in Florida.
The 1SG has MRC, 18" wheels, upgraded brakes, steering & mechanical cooling fan, cooled seats, more leather & wood trim, HID headlights with washers & auto high-beams. Maybe that's all available on other trim levels but probably not as common.
Take your time and you will find your car. Test drive one with & without MRC before you buy.
1BadCadSTS
12-28-10, 09:26 PM
342 is optional on 1SF & G 323 standard and ONLY 323 on AWD
in 05-06 ACC/HUD is 1SG only
EChas3
12-28-10, 10:10 PM
My '06 AWD 1SG has the 3:42.
1BadCadSTS
12-28-10, 11:15 PM
http://www.new-cars.com/2005/cadillac/cadillac-sts-specs.html
Per GM according to 05
Transmission Hydra-Matic 5L40-E (V-6 ) / Hydra-Matic 5L50-E (V-8)
1st 3.42 / 3.42
2nd 2.21 / 2.21
3rd 1.60 / 1.60
4th 1.00 / 1.00
5th 0.75 / 0.76
Reverse 3.02 / 3.02
Final drive ratio 3.42 / RWD: 2.73, 3.23, 3.42
AWD: 3.23
1BadCadSTS
12-28-10, 11:16 PM
2006
Specifications
Overview
Model:
2006 Cadillac STS
Body style / driveline:
luxury 4-door performance sedan with rear-wheel drive or all-wheel drive
Construction:
unitized welded steel body with direct-mounted front cradle and rubber-isolated, multi-link independent rear suspension assembly
Manufacturing location:
Lansing Grand River Assembly, Lansing , Mich.
Key competitors:
BMW 5 & 7-Series, Mercedes Benz E-Class, Lexus GS/LS 430, Audi A6, Jaguar S-Type
Engine
3.6L V-6 VVT
4.6L Northstar V-8 VVT
Type:
3.6L V-6 VVT
4.6L V-8 VVT
Displacement (cu in / cc):
217 / 3564
278 / 4565
Bore & stroke (in / mm):
3.7 x 3.37 / 94 x 85
3.66 x 3.3 / 93 x 84
Block material:
cast aluminum
cast aluminum
Cylinder head material:
semi-permanent mold aluminum
Valvetrain:
dual-overhead camshafts, 4 valves per cylinder, continuously variable valve timing
Ignition system:
coil-on-plug with extended-life dual platinum-tipped spark plugs
Fuel delivery:
returnless sequential fuel injection
Compression ratio:
10.2:1
10.5:1
Horsepower (hp / kw @ rpm):
254 / 189 @ 6500
320 / 238 @ 6400
Torque (lb-ft / Nm @ rpm):
252 / 339 @ 3200
315 / 459 @ 4400
Recommended fuel:
87 octane unleaded regular
premium recommended but not required
Maximum engine speed (rpm):
6700
6450
Emissions controls:
evaporative system, close-coupled catalytic converters, positive crankcase ventilation, inlet and exhaust cam phasers, electronic throttle control, feedback air-fuel-ratio control
Estimated fuel economy (mpg city / hwy / combined):
RWD: 18 / 27 / 24.4
AWD: 17 / 25 / 23.1
RWD: 17 / 26 / 23
AWD: 16 / 23 / 21.6 ($1,000 gas guzzler tax)
Transmissions
Hydra-Matic 5L40-E (V-6)
Type:
5-speed electronically-controlled automatic with lockup torque converter, Driver Shift Control, and Performance Algorithm Liftfoot
Gear ratios (:1):
First:
3.42
3.42
Second:
2.21
2.21
Third:
1.60
1.60
Fourth:
1.00
1.00
Fifth:
0.75
0.75
Reverse:
3.02
3.02
Final drive ratio:
RWD: 3.42
AWD: 3.23
AWD: 3.23
Chassis/Suspension
Standard/Luxury Package
Sport Package
Front:
independent, short/long arm, coil-over shock, anti-roll bar
Rear:
independent, modified multi-link, coil springs, automatic load leveling shock absorbers, anti-roll bar
independent, modified multi-link, coil springs, magnetic ride control, pneumatic load leveling, anti-roll bar
Traction control system:
full-range
full-range
Stabilizer bar:
Front:
hollow, 33-mm diameter
Rear:
RWD: hollow, 17-mm diameter
AWD: hollow, 24-mm diameter
RWD: hollow, 19-mm diameter
Steering type:
power-assisted rack and pinion; steering ratio: 18.2:1, variable ratio; ZF Servotronic II variable assist system available; steering ratio: 18.2:1, variable ratio
power-assisted rack and pinion; ZF Servotronic II variable assist system available; steering ratio: 18.2:1, variable ratio
Steering wheel turns, lock-to-lock:
3
3
Turning circle, curb-to-curb
(ft / m):
V-6 w/17-inch tires: 36.9 / 11.5
V-6 w/18-inch tires: 38.8 / 11.82
V-8 w/17-inch tires: 37.7 / 11.5
V-8 w/18-inch tires: 38.8 / 11.82
Brakes
Type:
power-assist – vacuum with anti-lock control, traction control and StabiliTrak
power-assist – vacuum with anti-lock control, traction control, StabiliTrak. Optional high-performance European brake linings
Rotor diameter x thickness
(in / mm):
front: 11.9 x 1.3 / 303 x 32 vented disc
rear: 11.7 x 1.0 / 298 x 26 vented disc
front: 12.7 x 1.3 / 323 x 32 vented disc
rear: 12.6 x 1.0 / 320 x 26 vented disc
Wheels/Tires
Wheel size and type:
17 x 7-inch cast aluminum or 18 x 8-inch flow formed aluminum
17 x 7.5/8.0-inch (split size) aluminum or 18 x 8-inch flow formed aluminum
Tires:
Michelin V-rated, 235/50R17 & 255/45R17 or Michelin ALS 235/50R17
Michelin V-rated, 235/50R17 & 255/45R17 or Michelin W-rated, 235/50R18 & 255/45R18 or Michelin Pilot Sport, 255/45R18
Dimensions
Exterior
Wheelbase (in / mm):
116.4 / 2956
Overall length (in / mm):
196.3 / 4986
Overall width (in / mm):
72.6 / 1844
Overall height (in / mm):
57.6 / 1463
Track (in / mm):
front: 61.8 / 1569
rear: 62.3 / 1581
Curb weight (lb / kg):
3.6L automatic: 3857 / 1750
3.6L automatic w/AWD: 3660 / 1795
4.6L automatic: 3921 / 1779
4.6L automatic w/AWD: 4230 / 1919
Weight distribution
(% front / rear):
V-6: 52 / 48
V-8: 54 / 46
Interior
Headroom (in / mm):
front: 38.7 / 983
rear: 37.9 / 962
Legroom (in / mm):
front: 42.6 / 1082
rear: 38.3 / 972
Shoulder room (in / mm):
front: 58.6 / 1488
rear: 57.4 / 1458
Hip room (in / mm):
front: 54.6 / 1387
rear: 55.6 / 1412
Capacities
EPA total volume (cu ft):
116.7
EPA trunk volume (cu ft):
13.8
Trailer towing maximum (lb / kg):
1000 / 454
Fuel tank (gal / L):
17.5 / 66.2
Engine oil (qt / L):
V-6: 5 / 4.7
V-8: 10 / 9.4
Cooling system (qt / L):
10.9 / 10.3
Seating capacity (front / rear):
2 / 3
http://www.cadillacfaq.com/gi/06sts.html
EChas3
12-29-10, 08:57 PM
My mistake. Mine's got the 3:23. Wow! The 3:42 must turn high RPM's at speed.
1BadCadSTS
12-30-10, 08:59 AM
NP if I was wrong I wanted to know, the 342s wouldnt launch as hard but on the highway that thing would jump when you punch it!
D&Ds_STS
12-30-10, 09:15 AM
2400 rpm @ 70 mph with 3.42.
EChas3
12-30-10, 09:00 PM
I would expect the 3:42 to turn more rpm @ 70. I think I turn 2,000 at 60. I'll check more closely next time I'm on the highway.
torogt
01-01-11, 12:32 PM
I would say 3.42 would be more responsive from launch all the way up threw all gears but would limit top end due to RPM's. When I bought my 06 I had no idea it was a 1SG I just liked the car! Mine does not have ACC/HUD. It seem like every car was optioned different depending on how the dealer ordered it or in my case mine was a presold order so how the customer ordered it. There is a 06 1SG for sale in SLC Utah for 10.5K 107K miles RWD but its silver. I guess if you look long enough you will probably find one the right colors and options.
05BlackV8BettySTS4
01-01-11, 06:19 PM
the AWD is nice. It handles nice in the snow when necessary. I live in NW Indiana (portion of snow belt). My cad is a pleasure vehicle, so for the days the roads are unplowed with 2 foot snow, I drive the 3/4 T 4x4 suburban.
EChas3
01-25-11, 08:27 PM
I took the time to check RPM & MPH closely. 2,000 RPM = 60 MPH (HUD) ~ 61 MPH (analog gage, by Cadillac spelling). This is 3.23?
If so, a 3.42 gear yields 57 MPH ay 2,000 RPM. Not very different.
Jesda
01-26-11, 12:37 AM
AWD isnt going to be tremendously better than RWD if your tires aren't giving you any traction.
