: Passenger side mirror! Help!
12-21-10, 11:07 PM
I need some help getting off the inside door panel so I can replace the door mirror. Can somebody help. Thanks.
12-25-10, 05:52 PM
I can't take you thru a step-by-step but one tip is that after you get the panel loose (all the clips and a few screws) you have to pull it away from the door enough to get the latch handle to release the mechanism and then push the entire panel UP. This will cause the two hidden inside clips to slide upwards on their track to release the panel from the door. For me this was the tricky part because I did not think it would work. Once you get it apart you then can look at how it was designed and it makes sense.
FYI, you must remount the clip retainers (2 [after you have removed them from the plastic clips]) back onto the slides in order to put the panel back into place and then pop the plastic clips back into the retainers by pressing on the panel once it is in place.
Confusing but it will work. Good luck.
12-26-10, 10:51 AM
Thanks, I'll try it later on.
