View Full Version : Error code P0455/P0449 2005 EXT
8ball
12-21-10, 07:42 AM
I tried doing a search but could not come up with anything. Has anyone had these codes before and if so what are they; P0455/P0449. It is a 2005 EXT with 72,000 on it. Thanks for any help I can get.
sams2100
12-21-10, 04:00 PM
P0455 - Evaporative Emission System Leak Detected (Gross Leak / No Flow)
P0449 - Evaporative Emission Vent Valve Solenoid Malfunction
I have a deville that has a similar emission code and its an EPA thing to keep gas fumes from escaping the fuel system. It doesn't harm the deville at all. As to your escalade, I have no idea if its going to hurt something or not, but probably worth asking someone about at AutoZone or somewhere similar.
8ball
12-22-10, 10:29 AM
Thanks, is anything of those hard to replace or is it something I can do at home.
ESV_Platinum
05-26-11, 02:24 PM
i have these exact same error codes on my 2005 Escalade ESV, is there any easy solution to this?? Please help!
ESV_Platinum
06-17-11, 04:40 PM
Bump
Sent from my iPhone using Tapatalk
g00dy
11-14-11, 01:59 PM
P0455 indicates a gross leak in the evaporative system. The most common failure is the gas cap. The Cadillac dealer told me aftermarket gas caps don't work on Cadillacs. I tried one from the local auto parts store and cleared the code. It was a Murray ultra 6817 ($7.99) and said it meets or exceeds all OEM specifications. It didn't fix the problem, next I'm trying one from Cadillac ($22.00). They had to have my VIN to give me the right gas cap. I've noted several people have had to replace their vent valve. Some Chevy truck owners replaced theirs ($160) with one from a cheaper car like a Cobalt ($40). It also could be one of the vent lines coming from the fuel tank, the Canister that collects the fuel vapors leaking, or the purge valve.
BizCzar
08-22-13, 05:34 PM
So what ever happened, I just got the P0455 code today, would love to hear how you ultimately solved the problem.
jnrsesv
08-23-13, 08:34 AM
BizCzar, you revitalized an old thread, I hope you get your answer.
the cadillac man
08-23-13, 10:38 AM
I got a emissions code like that and replacing the gas cap fixed it
flyingdutchman
08-23-13, 11:26 PM
See post # 9
http://www.tahoeyukonforum.com/forum...ad.php?t=16989
