View Full Version : how to replace washer bottle.
dcart1
12-19-10, 03:58 PM
have 2006 dts and started to take fusebox out and thought there might be more to it. Do you disconnect pos battery under seat or ground on engine. can you remove it by removing fender well?
Superjim
12-19-10, 05:13 PM
If "I" was going to mess with the fuse box... I would disconnect "BOTH" terminals on the battery under the seat.
Jim
tedcmiller
12-19-10, 11:56 PM
I think disconnecting the fuse box feed from its conection at the positive jumper cable connection under the hood (if there is one) would be sufficient. It is never necessary to disconnect the negative connection at the battery.
ltdltc
12-20-10, 02:00 PM
No need to remove the fuse box. Remove the splash shield and access is much better.
dcart1
12-20-10, 10:10 PM
do you mean the inner fender well thats plastic?
ltdltc
12-21-10, 05:09 AM
Yes.
