: Autoride removal - 06
chrisk1500
12-18-10, 08:34 PM
Does the 'pulling the RTD fuse' trick work when disabling the autoride on an '06 vintage Escalade or is it too new to be fooled that easily?
I am looking to ditch the air system and go to a set of gas Bilsteins....
Thanks!
nathanjax
12-18-10, 10:40 PM
03-06 is the same. remove negative on battery, wait 5 min, pull fuse, pull wires from front shocks, wait 5 min, put negative back on battery, done.
chrisk1500
12-19-10, 11:12 AM
So to do this properly I need to:
1. Remove air shocks - disconnect wires and air tubes
2. seal up now exposed air tube ends and connectors
3. Install gas bilsteins in all four corners
4. Pull negative cable - wait 5 mins
5. Hook battery back up and drive away
Am I missing any steps? I don't want any lights going off on my wife's rig....
nathanjax
12-19-10, 02:03 PM
Pull negative bat cable - wait 5 mins
pull fuse
chrisk1500
12-19-10, 04:32 PM
Perfect.
Thanks!
roboteacher
12-20-10, 08:23 AM
If you're going to replace the air system with the Blistein Shocks, I would consider the addition of the AirLift system http://www.cadillacforums.com/forums/cadillac-escalade-ext-esv-forum-1999/181602-helper-bags-installed.html . It's pretty easy and it still gives you the added support required to haul a heavy load.
Good Luck
sk7
12-21-10, 11:06 AM
chrisk1500, please post back your results if this was successful or not?
chrisk1500
12-21-10, 01:02 PM
I will be replacing all 4 shocks when I do this....may not get done for awhile though.
sk7
12-22-10, 04:07 PM
Kool! No hurry I'm still on oem shocks and all working good. Just wondering for the sake of other users who would like to go that route. Keep us posted!
