Cruis control is shutting off after about 20 mins? Sometimes a road bump will shut it off, sometimes i put it on (after 20 mins) at the wheel and the orange light comes on but when i try to set it the green light in cluster doesn't come on? Loose connection? Temp related? Any ideas for diagnosis? thnx.
I had this same problem cruise would work in the morning when cool out but if I hit a bump in the road it would cut out and in the afternoon when the temp was outside was high it would not work, dealer replaced clutch pedal sensor and cruise switch did not solve the problem, so they drove the car with computer tech 11 and it threw code that the clutch pedal was engaged so they finally looked under the hood and I had loose connection.
Related Threads
Cadillac Owners Forum
4.8M posts
369.7K members
Since 2002
