So back when I put on the headers I noticed some lines near the starter had the outside loom melted a little bit so I wrapped them up. The starter looked a little off to me even though I had never seen a starter but I kind of forget about. Well today I was cleaning the block where the heads seal and with the engine bay cleaned out I see this...
What do I need to do to fix this? The car has always started, but I can't see leaving it exactly like it is while I have so much access to it.
I'm pretty sure this has been this way a while and I'm assuming all of the problems I've had with the car are related? (rear most passenger exhaust manifold bolt was snapped off, rear most passenger MM to engine block bracket was only bolted in a few cross-threaded threads, and now this) Anything I should check around here that might have been messed up from before?
Thanks
Thanks
