View Full Version : leaking Water Pump 2000 dts cadillac
claymond
12-13-10, 02:14 PM
My 00 cadlillac dts water pump housing is leaking at the top, is this the gasket gone bad or dose my water pump need replacing.
Submariner409
12-13-10, 02:22 PM
There is a water pump housing cover redesign for 2000-2003.5. It uses a different seal (not a gasket - a formed silicone seal - think O-ring). Get in touch with a CF vendor, RippyPartsDept up in the Vendor threads ^^^.
Ranger
12-13-10, 02:23 PM
Water pumps leak at the shaft seal. You are looking at a gasket. Not sure where it's leaking , but if it's the front cover, that's an easy fix. If it is the crossover manifold, that will be a PITA.
