: 24" wheel offset?
12-12-10, 04:55 PM
Shopping for a set of 24" x 10" wheels and was wondering what offset 13mm or 30mm is everybody using? clearance issues better or worse with one offset or another?
12-12-10, 06:17 PM
I run 26" with the 30mm offset on my 04 but the only reason i went that route was so when i upgrade to a 07-up ext i could run them on it also i dont have and clearence issues i did trim some of the plastic in the well
12-18-10, 11:06 PM
anybody else got 24" wheels..what offset are you using?
12-20-10, 07:20 PM
there's nobody with 24" wheels that can share the correct offset?
12-21-10, 11:58 AM
I'm running 24 x 9.5's with a 30mm offset.
12-21-10, 08:23 PM
both offsets are correct 13mm is stock for 02-06 and 30mm for 07-up go with the 30mm so if you change to a newer gm suv or truck you can use the wheels the 13mm will not work well on newer
