View Full Version : Pressure... 80 cdv.
creeker
12-10-10, 10:10 PM
What's the optimum tire pressure for enjoying that old rear wheel drive
soft ride, but not harming tires by going too low on p.s.i..
sven914
12-10-10, 11:24 PM
32 psi is what the car is designed for, and it is debatable on whether your harming the tires if you move away from that (I say you are in the long run), but setting the tires at 30 psi should soften the ride with causing any noticeable edge wear.
cosmo
12-11-10, 11:12 PM
'76 recommends 24-28 psi on LR78/15, modern 235/75R15. Follow the sticker on the car, or the owner's manual, provided either still exist on your car.
Cosmo
