View Full Version : 1974-6 Cadillac dash removal/fuel economy indicator
lesinfamous
12-08-10, 11:37 PM
Anyone know how (in detail) to remove the dash from a 1974-6 Cadillac deville/fleetwood?
I am in the process of gathering the necessary parts needed for the fuel economy indicator system and the low fuel level indicator (red bulb).
Therefore, I need to access the area behind the telltale lights.
Thanks for your help!!
lesinfamous
12-09-10, 12:52 PM
Anybody at all???
75sled
12-09-10, 01:06 PM
I have an FSM for these, but I don't have acces to it until Monday as it is at work and I am off in class this week.
Hopefully someone will show a little love before then.
sven914
12-09-10, 05:39 PM
For anyone interested, lesinfamous sent me these from his service manual.
http://carphotos.cardomain.com/ride_images/3/3489/9/33720004011_large.jpg
http://carphotos.cardomain.com/ride_images/3/3489/9/33720004012_large.jpg
cosmo
12-11-10, 11:10 PM
To remove the middle dash panel: remove all screws underneath the louver 'shelf'. All will be through the chrome trim piece.
Next, remove the end louvers and the right centre louver. Do this by positioning the louver fully 'up' and carefully prying the pivots outward until you can remove the louver. Next, remove the two screws and one nut that are in the air ducts. Pull off the dash panel straight back. Careful, as the speedometer area is fragile.
Note on the economy indicators: they work to remind you, as the lights are within normal viewing. Interestingly, they are also progressive, the green will fade as the amber glows brighter whilst you leave lesser traffic behind.
Cosmo
lesinfamous
12-13-10, 04:06 AM
Sweet, Thanks for the info Cosmo!!!!
cadillac_al
12-14-10, 06:56 PM
What about the wiring? All the Caddys can't be wired for this set up can they?
sven914
12-14-10, 08:39 PM
^Not all of them have the vacuum switch. All '76-'79 Sevilles were equipped with the system, but it was an option on everything else in the '70's. But on the cars not equipped, the dash board connector has the pins for the wires and the slot for the bulbs are in the telltale, so wiring it in is very easy. The system hasn't been available as an option since 1980, but I wired it into my '89 using the factory telltale connector.
cadillac kevin
12-14-10, 10:34 PM
Sven, can you show how you added the economy indicator lights?
sven914
12-14-10, 11:40 PM
^The instructions are on page three of the 81 v8-6-4 fuel economy indicator???? (http://www.cadillacforums.com/forums/rwd-19xx-1984-deville-fleetwood-1985/204387-81-v8-6-4-fuel-economy-3.html) thread.
