: 2009 STS oil filter
bnagel
12-08-10, 02:09 PM
Is the oil filter one that drops in somewhere or is it like most traditional ones that spin off? Have not crawled under my car yet due to time but bought filter at NAPA and was handed one that dropped in. Where is it located anyways? I know it is a niave question.
Thanks
Ben
turnerbend
12-08-10, 11:35 PM
Is your car a v6 or v8? More than likely on the driver side under hood.
bnagel
12-14-10, 04:48 PM
V6. Under all the plastic?
carter's_sts
12-15-10, 12:31 PM
Canister right by the dip stick. Unscrew the top and replace the filter inside.
sub613
12-16-10, 07:15 PM
This is for a Northstar 4.6 V8. Just like a lot of things, Some come as regular, and some as Heavy duty.
ACDelco# PF-61, or, PF-61e , for extended.
FRAM# GM4718 or GM6094, or TG9837 or XG 9837 for Extended.
ALL screw on,oops, these are for a 2005 V8, BUt you get the idea..
Check the application sheet, it may be the same as above.
$ 4.00 to $5.50, depending on which one you pick.
Good Luck !:cool2::cool2:
