: 2000 heat problems
12-05-10, 06:45 PM
i was wanting to know if anyone has had this problem i have heat coming out of the passenger side vents and cold coming out the driver side
12-21-10, 01:22 PM
i would like to know if you know anybody out there that might know what causes the heater to blow heat then go to regular air and the a/c does the same thing blows cold air then goes to regular air, i dont hear any doors closing or opening but totally lost why itwould do this if you could be of help let me know
01-09-11, 02:26 AM
Bad control panel, from my experience
01-09-11, 11:31 AM
controll panel.. do yu mean the part in the dash witt he buttons yo push?
If so... I have one. the face will need to be swaped with your face cause the display has a crack and I swiped the lights behind the buttons for mine. but the actual part itsel I did use. I got it used from a 97 cat I think.
01-09-11, 03:51 PM
Yup. That panel fixed a lot of my problems
01-10-11, 03:20 PM
do you believe it to be that panel instead of the blend door? i have the same issue and was about to check out the blend door in the passenger side
01-10-11, 05:50 PM
The temp sensor is located in the ac control panel, it's possible it goes out. Have you tried turning the temp to 90 or 60 and then manually control the fan to keep temp moderate?
01-13-11, 08:32 PM
what do you mean by manually control the fan? try to move the actuator open/shut?
