: HT4100 (4.5 sleeves) Head Bolt Torque Sequence and Specifications?
12-02-10, 08:25 PM
I am finding differing head bolt torque specs in my manual, web and on here. I know there are multiple posts but could someone help me out?
I had to pull the head on a long block that I purchased with 4.5 sleeves. The #6 exhaust was stuck tight in the head....first crank bent a pushrod...head is off being fix.
thank you
12-02-10, 08:46 PM
found the specs alldatadiy... thanks
12-02-10, 09:07 PM
If you are not aware, you will need to insert the head bolt threads in the block to get a reliable torque...
