View Full Version : 3 out of 3: Intake Plenum
bigtone
11-30-10, 06:47 PM
For anyone out there that is wondering what percentage of 00-05 Northstars have a torn intake plenum, for me at least it's 100 percent. We have 3 Devilles in my household, 2 2001's and 1 2002. Last year I bought the second 2001 with a bad plenum. Within 2 weeks of changing it, the other 2001 lit up the SES light with the P0171 and 174 codes. Another torn plenum. I bought the 2002 for my wife this past September with 47k miles on it. I thought I would be off the hook with a plenum for a while. Now the 2002 has never been as good on gas as the 2001's, and had a slight miss at idle. The other day the SES light came on, good old 171 & 174. Just got done installing the plenum tonight, took 1 hr 15 minutes. Had a nice big hole in the bottom. Runs as it should. Hopefully the mileage will be come up a bit now. I'm still 2 out of 3 with the mode actuators, I'm waiting for it to go on the other 2001.
OffThaHorseCEO
11-30-10, 07:25 PM
that reminds me, i have an extra plenum i can sell. brand new in the box, didnt arrive until i got rid of my DTS
Ranger
11-30-10, 09:42 PM
At 7 yrs/85K mine is still good, but I fully expect it to go some day soon. How much do you want for it?
johnny kannapo
12-01-10, 02:31 AM
Why are these intakes going bad?
jimsbox
12-01-10, 04:16 AM
Yes, how common is this failure?
Submariner409
12-01-10, 10:27 AM
Synthetic rubber, heat, vibration, different rates of expansion between the plastic composite intake manifold and the aluminum throttlebody/water crossover casting, time, and oil and fuel vapor attack.
They all seem to split in the lower part of the bulge (bellows) so my guess is that's the place most subject to collecting moisture and acids from the PCV function - when the engine cools it pools there and the disintegration of the synthetic rubber begins.
For the model 2000,1,2,3,4 Northstar I'll bet it's a 100% failure, BUT time/mileage dependent.
It's probably a good thing that you can't see what's sitting in the bottom of the runner log in the intake manifold........................see that long flat part in this shot of an upside-down manifold ? That's where all the air begins its run up and around the tuned runner for each cylinder.
FWIW, This would be a perfect time to do a thorough TB cleaning - but the inside of the manifold is impossible, so don't even try.
Submariner409
12-01-10, 10:29 AM
Here's the plenum slipped on the manifold snout............
johnny kannapo
12-01-10, 01:02 PM
Good explanation.
So the clamped TB coupling is the part that fails?
Submariner409
12-01-10, 01:45 PM
Good explanation. So the clamped TB coupling is the part that fails?
Yep - here you go................
jimsbox
12-01-10, 02:30 PM
Sub, my DHS has 280,000 miles and the plenum has not failed yet. I am wondering, your opinion, replace now before I install the intake manifold or wait and see. Also, while I am at it, any tricks in mating the engine to the trans in the cradle, it was a pain in the nether regions separating the old ones. I am thinking of greasing the torque converter nub and the locator dowels but I am installing it alone with a shop crane.
Ranger
12-01-10, 03:11 PM
Jim,
Not to answer for Sub, but it is amazing that you made it 10 yrs and 280K without replacing the plenum duct. If I had to guess, I'd have to say it's days are numbered. Not expensive or difficult, but since you already have the manifold off, I'd replace it now.
jimsbox
12-01-10, 03:30 PM
Thanks Ranger. That is pretty much the way I am leaning.
Submariner409
12-01-10, 03:32 PM
:yeah: Yepper, yepper..............
RippyPartsDept
12-01-10, 03:36 PM
i would advise the same as Ranger, since it takes a bit of labor to get in there to replace the plenum (and the plenum is only about $35, list price) there's no reason to not do it, really
interestingly, i was just talking to one of my techs who was working on an '04 SRX w/ the N* engine and was asking for a plenum
i questioned him as to why those crack and he didn't give nearly as good of an answer as Sub just did
what was weird to me was that we've never done one of those plenums before for the longitudinally mounted N*'s before
i guess they may have improved on the pooling of 'stuff' inside there
AJxtcman
12-01-10, 03:54 PM
When the Cross-Over is done it can damage the Plenum Boot. Also if you don't loosen the clamp and just run the throttle body bolts back down after changing the cross-over gsk's you can twist the boot and it will fail.
The next time you see a customer with a bad boot look at the history and 75% or more of the time the Corss-Over was changed with in the last 12 months. Hmmmmmmmmmmmmmmmmmm
