: Nav Address sort
11-29-10, 09:04 PM
Does the nav system let you sort address listing or do just show up in order you entered?
Does the nav system let you put addresses into separate catagories?
11-29-10, 11:07 PM
As far as i can see, only in the order you entered, they show up. No categorizing seems available either. At least as far as i've seen.
11-30-10, 01:38 PM
You may not be able to sort them, but you can make a favorites list and use name tags for easy access.
11-30-10, 02:35 PM
Could you tell me how to make favorite list thanks
11-30-10, 06:18 PM
1. Press the "Destination" hard button.
2. Select "Previous Destination".
3. Pick your destination from the list.
4. Select "Mark". This saves the location to your address book.
5. Select "Edit".
6. Select "Add Voice Tag". Follow instructions to add a voice tag.
When you're in the "Edit" section you can also add/change the phone number, change icon, etc.
Use the voice command "Go To <Voice Tag>" to navigate to this location.
12-02-10, 01:17 PM
From the manual...
After the route has been
planned, press the NAV control
button until the full map screen
is shown.
2. Press the MENU/SELECT
control knob. A menu displays.
3. Scroll down and press the
Whole Route option. The whole
route map screen displays.
4. Press the Add Route screen
button. The route is stored as a
