: Brake Light Issue
oldworld
11-25-10, 09:59 PM
Hey guys:
My rear lamps all work. Running lamps work, turn signals also work both left and right....HOWEVER, only the driver side brake lights work, Third light works.
Passenger side brake lamps do not work. Obviosuly not the bulbs or the fuse.
ANY IDEAS?
Thanks
oldworld
11-26-10, 08:06 PM
I can remember having this same issue about a year or so ago...it was suggested that the contacts might be dirty on the connector which is located on the rear passenger quarter panel towards the rear. I took a look at it, and it was pretty dirty on the outside. There are 4 sets of wires that attach to that connector. Does anyone one know which color connector is the one for the passenger side brake lamps???
Nice to see there are alot of new people on here......lots of new names. Where are all the old guys?????sk7 always seem to be fun of info...you still around?
Any help would be appreciated. Otherwise I risk getting a ticket :-(
THANKS
oldworld
11-30-10, 01:02 PM
Does anyone know much about the four sets of wires that go to the junction box for the rear lights?
I am assuming that one set is a feed....
One set maybe for trailer lights???
anyone know which of the four controls the brake lights for the passenger side??
THANKS
sk7
12-01-10, 10:50 PM
Hey Oldworld! Sorry I missed ur post, thanks for the PM didnt know my inbox was full lol! I emailed u info on this issue, here's the wiring diagram and connector C4 info that supplies ground to both brake light sockets. Lmk how it turns out!
http://i438.photobucket.com/albums/qq102/sk7_1969/BL.png
http://i438.photobucket.com/albums/qq102/sk7_1969/BL1.png
Connector Part Information
• 15305597
• 7-Way F Global Tech 280 Series (BLK)
Pin Wire Color Circuit No. Function
A LT BLU 1320 CHMSL Supply Voltage
B BRN/WHT 2609 Right Rear Park Lamps Supply Voltage
C BLK 1750 Ground
D BLK 1750 Ground
E LT GRN 24 Backup Lamp Supply Voltage
F DK BLU 2115 Right Turn Signal Lamps Supply Voltage
H BLK 1750 Ground
http://i438.photobucket.com/albums/qq102/sk7_1969/BL2.png
93si
12-09-10, 02:50 AM
so did you figure out ur problem?? Im havin something similar on mine, my passenger brakelight light was burnt out i changed the bulb with a new one, it works fine along with the signal light, but now my Running lights dont work anymore but were working fine.
Anyone have a suggestion also??
Thanks
oldworld
12-10-10, 03:08 PM
Well....thank you sooooo much for this great information.....as always!!!
I took all of the 4 connectors off (they were very dirty) I sprayed some electronic cleaner spray on all the terminals on the connector terminals and on the junction block.
Put them all together and everything worked fine.
THANK YOU!!!!!
Too bad GM never made a cover to better protect that connector plate.
This is the second time in two years I has a problem with that same plate.
Anyway...for now all is good.
ON TO THE NEXT PROBLEM lol
sk7
12-10-10, 04:57 PM
I agree the location for that junction box is not great! Right behind the rear tire, and no protection whatsoever! Had to pry off tar and 5yr old mud off of mine when I was hunting for the ALC-SCM problem.
99eldoradodude
06-04-11, 09:53 AM
I'm having the same problem on a 1999 eldorado. Can anyone tell me where is this junction box located on my vehicle? thanks
muchacho34
05-24-12, 11:45 PM
can you or anyone repost the pics for the wires.. The large plug just past the junction box has a burned out pin I need to know which wire it is for.. I have no brake lights on passenger side and all the contacts are clean thank you in advance for all your help
Harley2012
07-10-15, 01:53 AM
Hi, I have 2004 Escalade. My passenger side rear running lamps and security light flash when I push remote to lock, does light up. All other lights work. I located junction box and connectors under rear wheel well, but I can't remove connector from junction box. Do I just pull wire retainer and then slide whole plug off or does plug snap in junction box with another retainer clip ? Thanks. Tried new bulbs, grease, and cleaning with no luck.thanks
DJCHRISNEAL
07-10-15, 10:41 AM
Guys I think this is my issue also. My rear right side of truck.
blinkers works
brake lights works
NO RUNNING LIGHTS
Where is this junction box you speak of. Left or Right side? Do I have to remove the tire?
the cadillac man
07-10-15, 11:04 AM
I think that's correct
DJCHRISNEAL
07-13-15, 08:22 PM
Problem solved. It was the junction box. It seemed water had gotten inside one of the plug and one of the pins had rusted and broke off. Thanks
the cadillac man
07-14-15, 01:31 AM
Yep that's gm's great idea to put it there(really dumb)
Glad to hear you got it fixed though
