View Full Version : Please help with 94 eldo trans trouble
alanhoggard
11-18-10, 05:08 PM
started when I was merging onto exway, check engine light came on, went into 3rd gear. When I would let off throtte it seemed to slip into neutral until getting back into therottle.
If i put it 3rd when starting out it would function normally 1-3,
got p029 code.
Dropped valve body and replaced shift solenoids, filter and added filter L bracket. Reassembled using correct torque.
filled with 6 qts.dexron VI. It is a bit low on dipstick. disconnected batt for 20 mins.
Now, it is doing the same thing as original problem but only goes into 2nd.
zonie77
11-19-10, 11:49 AM
The valve body bolts only need 10-12 ft lbs torque (look up the spec). Overtightening can cause a problem.
alanhoggard
11-19-10, 04:51 PM
I torqued them to 96 inch lbs.
Pete315
11-20-10, 10:13 PM
if you're close to Long Island NY and your car is a #9 vin car, I have a sweet shifting used tranny for sale.
