View Full Version : oil change
HD-Torsten
11-18-10, 11:52 AM
Hi Folks,
I want to thank my '73 DeVille change the engine oil, transmission oil and axle differential oil. I don't have a Service Manuel for my car. Which oil do I need? Can you help me there?
outsider
11-18-10, 01:13 PM
oil is probably 5w30. Tranny is most likely any Dex tranny fluid. axel oil...probably same as tranny? never did the axel oil in any of my cars!
sven914
11-18-10, 02:35 PM
Any Dexron transmission fluid will work. I'm not sure, but your engine might require oil with a certain ZDDP rating; check the official oil thread (http://www.cadillacforums.com/forums/rwd-19xx-1984-deville-fleetwood-1985/180150-type-engine-oil-curious.html) for information about that.
albymangled
11-18-10, 04:57 PM
G'day Torsten.
I have taken the following photos of pages in my Factory Service Manual for the 1970 year model.
I would be fairly confident your car uses the same types of lubricants.
I hope this information is of some use for you. The engine used in the 1970 model is the 472.
http://i29.photobucket.com/albums/c265/albymangled/oilviscosity.jpg
http://i29.photobucket.com/albums/c265/albymangled/oilcapacities.jpg
http://i29.photobucket.com/albums/c265/albymangled/factoryrecommend.jpg
By the way, your username HD-Torsten, does this suggest that you too are into Harleys?
OK good luck with the oils...
Alby.
creeker
11-18-10, 06:09 PM
Hi Folks,
What is the climate like where you live, does it get cold in the winter?.
HD-Torsten
11-19-10, 02:14 AM
Hi Folks,
many thanks for your help. This is really nice of you. Your information helped me a lot. The Caddy is driven only in summer (68 - 104F) and is in the winter in the garage. My Daylidriver is a Dodge RAM. Our temperatures drop in winter to 0F and lower.
best regards
Rock on
HD-Torsten
11-19-10, 07:31 AM
Hi Folks,
I now sometimes fought through the oil-thread and think that a 10W-40 oil is good for my caddy.
How do I get but the ZDDP additive ???
Thanks for your help !!!
best regards
Rock on
PS: my other hobby is Harley Davidson that's me (http://img697.imageshack.us/img697/1493/dsci0375.jpg)
HD-Torsten
11-20-10, 03:20 AM
Hi Folks,
I have found now on the Internet Lucas Oil. http://www.lucasoil.com/products/display_products.sd?iid=82&catid=9&loc=show&headTitle=%20-%20Engine%20Break-In%20Oil%20Additive%20-%20TB%20Zinc%20Plus
Can I use as ZDDP additives?
best regards
Rock on
