: Front end clunk after tire change/alignment.
11-17-10, 01:59 PM
Just replaced all 4 tires and had alignment. Now I have a suspension type clunk from the front when turning the wheels in either direction ( more noticeable on an incline) Doesn't do it all the time, and the dealer is having trouble duplicating it. Any ideas? I'm sure it has to do with the alignment..?
11-18-10, 04:33 PM
Loosened a tie rod and forgot to tighten it? That would cause movement in the tie rods when you turned, causing a clunk.
