Night Wolf
09-19-04, 10:09 PM
This has been happening since i got the car, I noticed it when I was installing my 4ch. amp int he car... water is leaking in, and it woudl pool up in the little valley where the parking brake cable goes thru the floor board... but it woudl flood the whole floor pan, which would soak the entire sound deadining materal, go thru the rubber part on that, then go thru the rubber part on the carpet and make the carpet damp... the carpet is actually discolored in the areas where it was wet.
So today I decided to tackle it, as well as a few other odds and end... turns out I had to remove *both* front seats, have all the carpet pulled up and completly take out the front sound proof material.... then I poured 1/2 gallon of water on the windsheild and looked in the car... atfirst i could only see 1 spot.. along some wires bundled up in a plastic case... but i set my camera to record a 30sec. movie while i pour the watter... looking back, it is coming in from 3 different places all in the same area... so it must be coming in, then just following whatever it can until it gets to the floor...
So far, from what I can tell, it is coming in on the bottom left edge of the windsheild... although that is just a guess... I don't know... another guess is a drain plug is clogged or the weather stripping is bad....
So I decided to take the upper part of the dash off (again) becuase I figured it may give me a better vantage point (I also changed all the lights from the once-cool blue, to white again... they fadded and looked bad)
So, with the dash off, I poured the water again... well, what took 1/2gallon before to get a decent amount of water int he car, I now poured 3 gallons of water on the windsheild, int he wiper cowling... everywhere in that area... and nothing!... this pisses me off becuase I know I didn't do anything to fix the leak, and now I can see anything... I had to pack up to go to work, I will spend more time with it tomorrow...
I am not going to go and start ripping apart the main part of the dash.... but the leak has to be somewhere back there... can anyone give me any info at all? anyone familer with this gen. DeVille? know water leaks? anything? I want to get this fixed though...
...the damage isn't as bad as I thought... forsome reason I thought the whole floorboard was rusty... but only the little nut on the parking brake cbale that is in the valley (always wet) is rusty... no big deal... and the sound deadining materal is soaked (had it in the sun drying today... not dry, will do it again tomorrow) the material is also rough, as the rubber part is cracked adn stuff from me trying to bend it while in the car....
Somebody please help me get this fixed :)
pics will be in reply
