: Parking lights
11-16-10, 09:22 AM
Anyone know how to change the parking light bulbs, have one that burned out and the dealer wants $60.00 to change it. Can't be that difficult is it ? This is the top bulb of the headlight assembly. Thanks in advance.
11-16-10, 10:17 AM
Replace with a 194 Wedge LED!
You pretty much simply just take the plug out 1/4 turn. There are two 10mm bolts on teh top of the headlight, there is a third that is hidden. Taking those two out should give you enough room. Depends on how big your hands are. Also helps to move the air box away . There is more discussion here on removing the entire headlight or making this easier.
If you have the $$ I would go ahead and take this opportunity to change both top lights for LED and the day time running lights as well.
11-16-10, 10:26 AM
Can you point me in the direction of all the discussions on how to take the headlight out? All i was able to find was a link to the Tahoe forums. I realize it's similar, but would like some more reference points before I tackle the job.
11-16-10, 05:57 PM
I started here
