: 106 octane in L37
mattbruz
11-15-10, 10:32 AM
What would that do to an l37 engine? Would in harm the engine at all? or would it benefit the engine due to the higher octane from premium?
Submariner409
11-15-10, 01:16 PM
Wouldn't do anything - higher octane ratings merely mean that the fuel burns slower so the engine can take advantage of slightly increased ignition timing - BUT the existing engine controls cannot move timing far enough to take that advantage, and the 4.6 Northstar doesn't require the timing advance of a longer stroke engine anyway.
mattbruz
01-29-11, 10:07 AM
In the midst of pulling codes, I went through the PCM data of the octane rating and it gave me 90. Is this normal? I have been using fuel additives for awhile. Like 104 octane boost and stp octane boost.
ThumperPup
01-29-11, 02:32 PM
not sure abou tthe GM Northstar's
but i know in my Mark VIII i woudl run 93 in it constantly always nevr lower sometimes 94 from sunoco
every ones in a whyll it would start to run ruff for some reason id run the engine down to about the last half gallon id go get a 5 gallon drump of 104 unleaded drop it in there and it would smooth out perfect
i guess it might do something to just run it threw keep it clean if you run it threw ones a year perhaps but not reeally sure
Submariner409
01-29-11, 04:08 PM
In the midst of pulling codes, I went through the PCM data of the octane rating and it gave me 90. Is this normal? I have been using fuel additives for awhile. Like 104 octane boost and stp octane boost. You have thrown away a lot of gasoline $$$ in the process..............
There is absolutely NO reason to run so-called "octane boosters". If you read the fine print it will say something like "Can raise octane by X points". Points - as in 87 octane to 87.2 octane. Snake oil at its finest hype.
You wanna "raise octane" ??? Go the local liquor store and buy a fifth of 190 proof grain alcohol (ethanol !) and dump it into a tank fillup. Ethanol is an octane booster because it slows down the rate of combustion and cools the combustion process.
Post #2
mattbruz
01-29-11, 08:07 PM
U probably already know this but I have a 20 gallon tank. Would the fifth cover the whole 20?
Submariner409
01-29-11, 09:37 PM
Put this all in context - you're searching for some sort of "performance increase". My post was tongue-in-cheek advice that you might as well forget it from a standpoint of pouring magic potions into your gas tank ! Think about it: Your tank holds 20 gallons of gasoline. 1/5 gallon is 1/100 of the total volume........so you would be far, far better off by running a decent brand of 89 or 93 octane gasoline - Chevron, Shell, or Texaco. Google "top tier gasoline" to find out why.
Ranger
01-30-11, 12:16 AM
:yup:
zonie77
01-30-11, 12:27 AM
As Sub said, high octane gas burns slower...and it's resistant to "knocking" so it can support higher compression. If the engine was designed to need 100 + octane you would get a benefit. Since the N* is designed to run on lower octane you will get little or no benefit. The timing will advance more, but I think the computers are fairly limited in max advance.
A long, long, long time ago, when dyno tuning ruled the earth, HAHA , I would have to manually adjust timing for different octane gas, but it still wasn't a huge difference.
mattbruz
01-30-11, 10:43 AM
Well I am now just seeing the light in all of this.*sigh* I have been using bp but I'll look it up as you said. I know engine is amazing for it being stock. I was just looking for better mpg in the city. I currently get 13.6-17 mpg city. 17 mpg being very conservative on the pedal. And 13.6 dogging the engine for performance.
Submariner409
01-30-11, 10:49 AM
If you're getting 13.6 - 17 in the city that's right in the ballpark with every other Northstar owner. ETC/DTS/STS should see ~24/25 on the Interstate. ELC/Deville/DHS/SLS, about 26/27. The difference between model types is the 3.71 final drive compared to the 3.11.
97EldoCoupe
01-30-11, 01:17 PM
Or like my one '97, have the L47 Aurora 4.0 motor coupled to the 3.11:1 final drive in an Eldorado. Nobody can beat my highway mileage :)
mattbruz
01-30-11, 01:33 PM
3.71; I guess I shouldn't be too worried about it.
