: 2005 escalade esv - Sunroof leaks. Need advice!
gerwin
11-07-10, 06:01 PM
So I was going through the car wash, and all of a sudden water started dripping from the overhead heater console unit. (I live in Vegas, so we don't see much rain) Seems water is coming through the sunroof and running down into this unit before dripping.
Anyone know where to get a new seal, and how much it costs? I called the Cadillac dealer and his response was it shouldn't leak, is it aftermarket? I said no, its stock, and he didn't have an answer. Great help, Cadillac service advisors are more retarded them BMW ones.:bomb::banghead::cookoo:
Thanks in advance for any help!!!:o
sk7
11-07-10, 08:48 PM
I've had to mess with my sunroof assembly for a few months while fixing the roof of my truck. My guess would be that one (or more) of the drains (theres 4 of em) are blocked and the tray fills up and spills onto the headliner. With glasspanel open you should be able to see the tray and the two front drain. Is it full of water already? Use a pitcher (empty the beer outta there first, no instructions needed here...) and slowly fill the tray and see if it empties itself. The rear drains are a bit of a pain to get to. Headliner need to come off. If they are blocked you might be able to get by using a clothes hanger and unblock it. I still have my old assembly I can take pics of for reference. Keep us posted.
GaExt
01-28-11, 05:58 AM
sk7 do you still have the pic of the frame rail or your assembly of the drain for the sunroof.I am having a little issue of leaking from my sunroof into the inside.I saw this post and though i give it a shot for any answer
sk7
01-28-11, 10:08 PM
Yep the old sunroof assembly frame rail is sitting in the attic of the garage. I'll try and take a pic of the assembly this weekend and post it here.
jnrsesv
01-30-11, 12:29 AM
excellent advise! especially about getting rid of the beer first!
weaponXprogram
05-05-15, 03:16 PM
My sunroof leaks a little as well, but it seems that it is due to the weather stripping around the glass not the drains. I don't have the sunroof shade either so it leaks directly onto my seats if I leave it out in the rain. When I say leak, I mean it slowly drips water in.
Does anyone know where I can buy a new sunroof shade from?
the cadillac man
05-05-15, 05:34 PM
My sunroof leaks a little as well, but it seems that it is due to the weather stripping around the glass not the drains. I don't have the sunroof shade either so it leaks directly onto my seats if I leave it out in the rain. When I say leak, I mean it slowly drips water in. Does anyone know where I can buy a new sunroof shade from?
You might have luck looking on line or at a salvage yard
blaze190
05-06-15, 09:04 AM
When my 05 started leaking in the car wash I noticed the glass part of the sun roof wasn't fitting tight in the opening anymore. I did a little research and found a reset procedure on the electronics of the sun roof. When I did the procedure it made a loud pop and lifted straight up to the vent position then when I closed it I noticed it lifted higher up in the opening making it fit tighter and stopped it from leaking.
All I had to do to reset it was press and hold the closed button for about 30 sec to a min and it made a pretty loud pop and lifted up into the vent position. Then all I had to do was close it and it was fitting much tighter in the opening.
Hope this might help.
teddybear8203
05-06-15, 01:22 PM
i had the same water leaking into roof console. i opened up the sunroof and blew air down through the drains tubes. also cleaned all the debris that was up there with the air. no leaks since!!!
weaponXprogram
05-06-15, 04:53 PM
Thanks for the input guys....I have already done the reset. I will blow out the drain tubes. But the leaking is happening where the sunroof weather stripping comes into contact with the metal roof.
