I have had two instances of cam position failures. The first I got fixed at the dealership, (mega expensive). The most recent one I would like to fix myself. Can anyone help?
It appears that there are four sensors; two right bank (exhaust and intake) and two left bank (e & i); that may be why it costs so much for replacement. It appears fairly easy to perform (after you gain access; removing engine site shields and the left bank requires you to loosen the power steeting pump), then disconnect the electrical connectors, loosen (one) bolt and remove sensor. When installing, lubricate the "O" ring, re-install the retaining bolt and reconnect electrical connector.
Their connector plugs are prone to corrosion. They may only need to be cleaned & greased to work again. In fact, may have been all the ones you replaced needed....
I have been trying to find an aftermarket manual for the 05 STS and there doesn't seem to be one! Does anyone know who publishes one?
Related Threads
Cadillac Owners Forum
4.8M posts
369.7K members
Since 2002
