View Full Version : Gas Engine Tune Up Specs
Dead Sled
01-27-03, 02:28 PM
Year
1967
Engine No. Cyl. Disp. CI (L)
8-429 (7.0)
Fuel Delivery
4V Carb.
Engine Manufacturer
Spark Plugs - Origional Type, Gap (in.)
44 0.035
Distributor Point Dwell (Deg.), Point Gap (in.)
30° 0.016"
Ignition Timing Deg. BTDC (Auto. Trans)
5B
Intake Valve Opens BTDC
39°
Fuel Pump Pressure
5.75 PSI
Idle Speed (Auto Trans)
500 RPM
__________
Year
1968-1969
8-472 (7.7)
Fuel Delivery
4V Carb.
Engine Manufacturer
44N 0.035
30° 0.016"
5B
18°
Fuel Pump Pressure
5.75 PSI
550 RPM
Dead Sled
01-27-03, 04:53 PM
Year
1970-1971
8-472 (7.7)
Fuel Delivery
4V Carb.
Engine Manufacturer
R46N 0.035
30° 0.016"
8B
18°
Fuel Pump Pressure
6 PSI
600 RPM
__________
Year
1970-1971
8-500 (8.2)
Fuel Delivery
4V Carb.
Engine Manufacturer
R46N 0.035
30° 0.016"
7.5B
18°
Fuel Pump Pressure
6 PSI
600 RPM
Dead Sled
01-27-03, 04:58 PM
Year
1972-1973
8-472 (7.7)
Fuel Delivery
4V Carb.
Engine Manufacturer
R46N 0.035
30° 0.016"
8B
34°
Fuel Pump Pressure
5.25-6.25 PSI
600/400 RPM
__________
Year
1972-1973
8-500 (8.2)
Fuel Delivery
4V Carb.
Engine Manufacturer
R46N 0.035
30° 0.016"
8B
34°
Fuel Pump Pressure
5.25-6.5 PSI
600/400 RPM
Dead Sled
01-27-03, 05:03 PM
Year
1974
8-472 (7.7)
Fuel Delivery
4V Carb.
Engine Manufacturer
R45NS 0.035
30° 0.016"
10B
21°
Fuel Pump Pressure
5.25-6.25 PSI
600/400 RPM
__________
Year
1974
8-500 (8.2)
Fuel Delivery
4V Carb.
Engine Manufacturer
R45NS 0.035
30° 0.016"
10B
21°
Fuel Pump Pressure
5.25-6.5 PSI
600/400 RPM
__________
Year
1974
8-500 (8.2)
Fuel Delivery
4V Carb.
Engine Manufacturer
R45NS 0.060
Electronic (HEI)
10B
21°
Fuel Pump Pressure
5.25-6.5 PSI
600/400 RPM
Dead Sled
01-27-03, 05:06 PM
Year
1975
8-500 (8.2)
Fuel Delivery
4V Carb.
Engine Manufacturer
R45NSX 0.060
Electronic (HEI)
6B
21°
Fuel Pump Pressure
5.25-6.5 PSI
600/400 RPM
__________
Year
1975
8-500 (8.2)
Fuel Delivery
EFI
Engine Manufacturer
R45NSX 0.060
Electronic (HEI)
12B
21°
Fuel Pump Pressure
39 PSI MIN.
600 RPM
Dead Sled
01-27-03, 05:12 PM
Year
1976
8-350 (5.7)
Fuel Delivery
4V Carb.
Engine Manufacturer
Oldsmobile
R46SX 0.080
Electronic (HEI)
10B (6B)
22°
Fuel Pump Pressure
5.25-6.5 PSI
600 RPM
__________
Year
1976
8-500 (8.2)
Fuel Delivery
4V Carb.
Engine Manufacturer
R45NSX 0.060
Electronic (HEI)
6B
21°
Fuel Pump Pressure
5.25-6.5 PSI
600 RPM
__________
Year
1976
8-500 (8.2)
Fuel Delivery
EFI
Engine Manufacturer
R45NSX 0.060
Electronic (HEI)
12B
21°
Fuel Pump Pressure
39 PSI MIN.
600 RPM
Dead Sled
01-27-03, 05:19 PM
Year
1977
8-350 (5.7)
Fuel Delivery
4V Carb.
Engine Manufacturer
Oldsmobile
R47SX 0.060
Electronic (HEI)
10B (6B)
22°
Fuel Pump Pressure
5.25-6.5 PSI
650 RPM
__________
Year
1977
8-425 (7.0)
Fuel Delivery
4V Carb.
Engine Manufacturer
R45NSX 0.060
Electronic (HEI)
10B @ 1400 RPM
21°
Fuel Pump Pressure
5.25-6.5 PSI
675 RPM
__________
Year
1977
8-425 (7.0)
Fuel Delivery
EFI
Engine Manufacturer
R45NSX 0.060
Electronic (HEI)
18 @ 1400 RPM
21°
Fuel Pump Pressure
39 PSI MIN.
675 RPM
Dead Sled
01-27-03, 05:23 PM
Year
1978
8-350 (5.7)
Fuel Delivery
EFI
Engine Manufacturer
Oldsmobile
R47SX 0.060
Electronic (HEI)
10B (8B)
22°
Fuel Pump Pressure
5.25-6.5 PSI
650 RPM
__________
Year
1978
8-425 (7.0)
Fuel Delivery
4V Carb.
Engine Manufacturer
R45NSX 0.060
Electronic (HEI)
18B @ 1400 RPM
21°
Fuel Pump Pressure
5.25-6.5 PSI
650 RPM
__________
Year
1978
8-425 (7.0)
Fuel Delivery
EFI
Engine Manufacturer
R45NSX 0.060
Electronic (HEI)
18 @ 1400 RPM
21°
Fuel Pump Pressure
39 PSI MIN.
675 RPM
lux hauler
01-27-03, 05:32 PM
Dead Sled,
Lots of info there. Thanks for posting it.
Dead Sled
01-27-03, 05:34 PM
Year
1980
6-252 (4.1)
Fuel Delivery
4V Carb.
Engine Manufacturer
Buick
R45TSX 0.060
Electronic (HEI)
15B
16°
Fuel Pump Pressure
4.25-5.5 PSI
550 RPM
__________
Year
1980
8-368 (6.0)
Fuel Delivery
4V Carb.
Engine Manufacturer
R45NSX 0.060
Electronic (HEI)
18B
11°
Fuel Pump Pressure
5.5-6.5 PSI
575 RPM
__________
Year
1980
8-368 (6.0)
Fuel Delivery
DFI
Engine Manufacturer
R45NSX 0.060
Electronic (HEI)
10B
11°
Fuel Pump Pressure
12-14 PSI
575 RPM
Dead Sled
01-27-03, 05:40 PM
some where I have the 80-present specs I'll keep looking
stupeds
10-03-04, 02:46 PM
shouldnt the sparkplug gap on the 74 500 and 472 be .060 with the hei dist?
Dead Sled
11-04-04, 11:18 PM
if it has HEI yes if not those specs above are for piont type
stupeds
11-18-04, 01:44 AM
yeah thats what im trying to say. the 4th post and the 3 engine described is a 74 500 with hei, but you have the gap at .035 when it should be .060 just wanted to give you the heads up so people done set the gap wrong.
Dead Sled
12-23-04, 08:22 PM
ahh fixed it
Devillian86
06-08-05, 04:35 PM
Any chance of getting specs for a 79 deville?
thanks
davesdeville
06-08-05, 06:37 PM
79 specs should be the same as 78 as far as I know.
The Ape Man
09-11-05, 01:30 PM
According to Chilton 1984 Parts and Labor Guide:
'79 425 W carb = 23 btdc checked at 1400 RPM. (not the same as 1978)
Fuel injected = 18 btdc which IS the same as 1978.
Some of these books AND the specs posted here are incorrect. They show figures of how many degrees before top dead center the intake valve opens on engines of different years. When you look up the internal engine items such as camshafts, timing gears, etc. they are all the same exact part numbers. Something is wrong.
davesdeville
09-12-05, 06:43 AM
I said what I said because there were no physical changes between 78 and 79 engines. Who has got a factory service manual, anyone?
deville_in
10-23-05, 08:11 AM
Since there is some interest and knowledge regarding "Old School" Caddy's - Can anyone direct me to any info on buying the right radial tires for a 1970 Coup Deville Convertible.
the ones one Bebe are (I think) the wrong size - my speedo is off by about 8 miles an hour and the exhaust (on a rare occasion) bottoms out.
