View Full Version : Key Fob
Mark58
10-27-10, 05:20 PM
What am I doing wrong?
bought a new key fob from dealer and had it programmed. Original fob unlocks doors, locks doors,opens trunk, remote starts the car moves the seats set for driver #1.
New fob does everything but does NOT MOVE THE seats at all???
dealer told me twice there is nothing wrong with it!!!
Any Ideas?
Thanks
Mark58
10-28-10, 09:55 AM
Any Ideas?
Thanks
Found the answers on this site.
First set the seats, Steering wheel (jf power telescoping) Rear view mirrors to desired position. On your door press # 1 or #2 to save in memory. Now follow the instructions I found on the site.
Use the following steps to program your remote:
 1. Press the vehicle information button until press (a check mark) to relearn Remote Key Displays
2. Press the set/reset button until "REMOTE KEY LEARNING ACTIVE" displays
 3. Press and hold the lock and unlock buttons on the first keyless remote at the same time for apprx. 15 seconds. A chime will sound indication that the remote has been programmed.
 4. To program additional remotes at this time repeat step 3. This vehicle can have a max of 8 remotes programmed.
5. To exit program mode turn key off and remove the key.
6. Test remote
Read more at http://www.cadillacforums.com/forums/cadillac-escalade-ext-esv-forum-2007/185425-key-fob-programming.html?ktrack=kcplink
Superjim
10-28-10, 01:35 PM
6. Test remote
I assume that worked for you.
Good info.
Thank you.
Jim
Mark58
10-28-10, 03:38 PM
Good info.
Thank you.
Jim
Yep,,works great and it took all but 2 minutes.LOL
