View Full Version : 07 escalade heated seats
john@atrlimo.com
10-24-10, 07:29 PM
07 Escalade heated seats in the front do not work. I cannot find a fuse or a circuit breaker in the manual, or marked in any of the fuse boxes in the car or under the hood. Any ideas??
cadmanchris
10-24-10, 08:14 PM
Check under passenger seat for climate control seat module. Disconnect the bigger connector and inspect for burned terminals. If it is burned, connector or terminal must be replaced and sometimes module itself also. If you have a hard time pulling the connector off, chances are that your have burned terminals. HTH.
SouthernCaddy
10-25-10, 12:17 PM
yep he is right, something happend to my truck. But the Heat and cooled part did not work. Does you cool part work?
