: BLS Winshield wiper
10-24-10, 09:24 AM
Hello Guys
I am new on this forum, I am in Norway and my car is a 2006 BLS 1,9TD. My problem is my wipers which do not park properly, they stops in the middle of my sight, there are no way to get them park in the right position. Do you have any suggestions of this problem??
10-26-10, 02:21 PM
sounds like the motor is out of sync, i guess thats going to be a garage job
12-19-10, 12:14 PM
Hi' siclone,
Did you find a solution? I have the same problem with mine.
My nearest dealer is quite some distance away.
02-08-11, 01:21 AM
On my BLS the wiper would stop half way up the windscreen, then it went slow and finally stopped.
My local garage fixed it. They said that the bush which goes between the spindle and the motor had siezed up. So they cleaned it up and used some wd40. Works fine now.
02-08-11, 04:39 AM
you cant beat a bit of WD40
