: 04 Power Seat and Heated Seats Not Working
TobyJohnson11
10-21-10, 12:00 AM
The drive side power seat and heated seat stopped working at the same time. The passenger power seat works but not the heated seat. Any ideas? I canít find a fuse for the power seats or heated seats.
TobyJohnson11
10-23-10, 01:35 PM
Any ideas yet? I still havent found a fuse issue.
BlownEscalade
02-23-12, 11:19 PM
same thing just happened to me. any ideas?
the cadillac man
02-24-12, 12:40 AM
was the seat module checked it sounds like it going but i don't know if it works both the seat warmer and movement i guess it does since it is in with the memory controls.
BlownEscalade
02-24-12, 10:07 AM
Fixed it. Did a bit of research and all you have to do is flick the key in the ignition back and fourth a couple times without starting and it fixed it :)
the cadillac man
02-24-12, 08:36 PM
Fixed it. Did a bit of research and all you have to do is flick the key in the ignition back and fourth a couple times without starting and it fixed it :)sounds like the ignition switch is going to need replacing soon as it will get worse as it ages and wears just a heads-ups
dandel
03-05-12, 08:19 PM
i got the same and it was the main power under the driver seat the connector start to burn i just connect that one directly
Caddie Shak
03-06-12, 05:11 PM
^^^ The connector was starting to burn? That doesn't sound good, maybe it wasn't plugged in all the way and wasn't making a complete connection?
BlownEscalade
03-24-12, 10:15 PM
which connector is it?
