: hid kit
10-20-10, 04:12 PM
anyone.install.a.hid.kit.in.a.02.escalade?:confuse d:
10-20-10, 04:46 PM
First off whats with the periods at the end of each word lol... Secondly what are you having trouble with?? Almost every HID kit out there is plug and play.. You just put the adapter thats included with the kit onto the bar plugs of the ballast and then plug into your stock headlight plug.. If you want to go the extra mile and worry that the stock wiring might fry you can step it up a notch and grab a relay harness which is the same concept only you hook up 2 additional wires to positive and negative of battery.. HID install is pretty straight foward these days.. Might want to elaborate on what you need help with..
10-26-10, 07:29 PM
I actually put HIDs on my escalade and it did have the adapter and I found that the connection is switched on the adapter. You just need to switch it around so the positive and negative are connected to the right spot.
