: Almost Have The Door Panel Off 94
09-16-04, 02:01 AM
I Pulled It Out Of All The Notches And Screws On The Left Driver Side Door. My Window Wont Go Up No More, So Im Thinking Maybe The Motor Died For The Window. So Im Trying To Take The Door Panel Off, But Im Stuck On The Last Part. I Need To "unhook" It From The Top Part Of The Door, Where The Window Comes Out
Any Suggestions?
09-16-04, 11:47 AM
I'm not 100% sure on the 94 fleetwood but most gm door panels are just snapped down on and are kind of tough to get off for the first time. With one hand pull out the bottom of the panel a couple of inches and then apply some upper pressure. Then using the palm of you other hand hit the panel about 2 or 3 inches below the top. Hit inward and upward as to bump the panel in closer to the window and with the combined upper pressure this should dislodge the panel.
09-19-04, 03:59 PM
Thanks Man
Sure Enough That Did It. Unfortunaltly, It Looks To Crazy To Mess With. Ima Pay 180 To Fix It, But I Think I Might Be Able To Do It, But I Dont Really Wana Mess Up The Brougham
