: DTS 2006--Check codes on Board and reset-
SteveBeard
10-06-10, 11:07 AM
Check engine icon came on. Lite steady, books said check gas cap.
I know on one of my older Caddy's I could do a on-board check and then clear or set.
tedcmiller
10-06-10, 12:11 PM
On older Cadillacs you could do everything from the dash board (look at codes, reset them, etc.). On the newer Cadillacs you can do nothing from the dash. You have to attach a diagnostic tool to the OBD port and do everything using the tool. Most Sears stores and automotive stores (Advance, Pep Boys, AutoZone, etc.) have them at various prices and various capabilities. Be sure and get a new one that has the CAN interface. Without CAN capability, the tools might not work on some cars.
SteveBeard
10-06-10, 02:24 PM
Thanks, I was checking into purchasing the tester at AutoZone and they ran the test for me at NO Charge. It was what I figured it was going to be (catalytic converter)
Thanks
Superjim
10-06-10, 10:26 PM
Thanks
If you have less than 80,000 on it...the Catalytic converter will be under warranty.
Texas Jim
