View Full Version : Differential fluid change
mannyz
09-30-10, 11:38 PM
Hey fellas, I need some quick help. I am changing my diff oil tomorrow and can't seem to figure out whether I need the additive or not for my V. I have mobil 1 LS 75w-90 gear oil. The bottle says additive is not necessary for certain applications. I'm leaning towards just adding it since not adding it and it being required would cause damage. I've heard if additive is not needed and you use it, you will lose power to the wheels because of too much slippage. Please advice :)
DrumStix
10-01-10, 10:03 AM
Yes, I put it in.
mannyz
10-01-10, 12:19 PM
Thanks a bunch.
jwa999
10-01-10, 05:21 PM
My dealer added 2 bottles of additive to my 09 V. IT was around 10,000 miles when i noticed the rear diff started making noises first thing in the morning.
thebigjimsho
10-01-10, 09:06 PM
DEFINITELY put it in. But if you use Amsoil or Red Line, it's already incorporated into the fluid.
mannyz
10-01-10, 09:31 PM
I added one bottle of additive and about 1.5 quarts. Car seems to be running smoother. The fluid was really dark as everyone mentioned. Everyone at the shop was acting shocked that I was using mobil one and not royal purple. Does using amsoil 75w-90 void our warranty?
thebigjimsho
10-01-10, 09:38 PM
Just tell them it's Mobil 1. If any service writer told me it did, I'd laugh at them...
mannyz
10-01-10, 09:53 PM
Next time I'll switch to amsoil. There's tons of debates out there on which oils are better for our cars.
RapidRob
10-01-10, 10:18 PM
I had my rear-diff. oil changed at 1500 mi., and again at 11.5K mi. for good measure, - by the dealer. Brought my own AMSOIL rear-diff. oil both times and dealer made no mention of warranty issues or possible problems.
Rob
mannyz
10-01-10, 10:26 PM
My dealer is on crack.... They quoted me $70 to change the gear oil even if I brought my own. That's why I did it myself.
thebigjimsho
10-01-10, 10:33 PM
The transfer pump Amsoil sells makes it SOOOOO EASY. a set of Rhino ramps and a pump and it takes 7 minutes, maybe...
mannyz
10-01-10, 10:40 PM
I used the pump that you attach to the bottle... Kinda like a lotion pump. Man and I thought masturbating made my arm tired! :)
baabootoo
10-02-10, 12:32 AM
Heat it in the microwave first........ :)
GMX322V S/C
10-02-10, 07:43 AM
Heat what?
baabootoo
10-03-10, 02:43 PM
The fluid, then it pumps easier. You won't even need a pump. Just connect a hose to the bottle and squeeze it in.
