: the shift solenoids
93 STS
09-14-04, 12:27 AM
were dose the brace bolt to on the solenoids.
09-14-04, 01:55 PM
Are you talking about the mounting brace that came in the solenoid kit? if so it is place over the black square filter that fits between the 2 solenoids and the bolt that comes in the kit it a longer replacement for the valve body bolt. Just put the brace over the filter and you will see where the bolt goes.
93 STS
09-17-04, 10:35 PM
Thanks for the tip.I put the solenoids in and didnot use the brace.
work for one day. took it apart found the filter out of place.
installed the brace the trans shifts again.thanks for your time
