: Less Expensive Differential Cooler
09-27-10, 02:14 AM
After doing some searching, I found a Tilton 12 VDC cooler pump that is made for transmission and diff lubes. I plan on using this, a heat-sink type cooler (mounted on the frame), and an on/off switch. If this type cooler won't work for you, get a flat type cooler in the air flow. Looking up some prices on Summit, you can get the cooler, pump, SS lines and fittings easily for under $400. Not as slick as the GM one, but then again.........
09-27-10, 09:39 AM
09-27-10, 09:51 AM
pretty sweet!
09-28-10, 01:08 AM
Yep, nice find!
09-30-10, 03:31 PM
Hey just FYI..those Tilton pumps are noisy. If you can find a good gear driven pump would be better.
10-02-10, 01:50 AM
Since I'll only be using it on the track, with the exhaust noise, engine whine, and open windows, I bet I'll hardly notice it!!!!!!!! :)
