: sudden switch off (1991 fleetwood)
09-24-10, 02:30 PM
the car switches it self off without any warnings after driving in the city for more than 1 hour (1 to 2 hours), the average driving speed when problem occured is (25 miles),
only for 1 time problem occured while the car in reversing status for parking !
I can switch it on immediately & complete driving
following parts have been changed but it didn't fix it
battery, fuel pump, fuel filter, spark-plugs with wires
I need solution :stirpot:
09-24-10, 05:21 PM
Maybe ignition related?
09-26-10, 05:18 AM
could you please prvide some elaborations?
09-26-10, 10:27 AM
Trouble codes?
09-27-10, 04:16 PM
Does the car give any indication it is about to stall? Such as the idle suddenly gets rough or really slow.
Does the issue occur when you are off the gas or on the gas? If it happens while you are accelerating, does it feel like suddenly there is no power for a second before the engine stalls? Or does it feel like someone turned off the key?
Some other areas to look are the ignition coil, the fuel injectors, and the torque converter clutch.
