View Full Version : Thermostat
snzuloz
09-13-10, 07:17 PM
Does anyone know if the 160 degree thermostat is a GM O.E.M. part or equivalent that people are switching too? If so does anyone have the part number for it?
Gary Wells
09-13-10, 08:31 PM
Troy:
Something you should know:
http://www.cadillacforums.com/forums/cadillac-cts-v-series-forum-2009/174915-how-many-running-160-thermostat.html
musclesbmf
09-13-10, 10:13 PM
All the vendors sell the Motorad t-stat. Same stat that corvettes use.
Mark
Domsz06
09-13-10, 10:13 PM
any of your supporting vendors can get it for you. Not sure I would want to run it in Alberta unless you never drive the car in the winter. These cars are designed to run hot for a reason.
snzuloz
09-13-10, 10:44 PM
This car is definately not Alberta winter friendly, Im not even going to attempt it, it just keeps the car in pristine shape without all the salt and gravel.
I just thought someone would have a number that works, getting parts sent up costs a lot when you factor in exchange rates and shipping and additional taxes etc etc.
baabootoo
09-14-10, 02:19 PM
Depending upon where you look, the stocker shows 192 or 195 F. It's been like this for a LONG time too. I thought part of it was to burn off water in the fluids, since 180+ was needed. Hence, less sludge.
Domsz06
09-14-10, 02:50 PM
where in alberta do you live? I may be up there in 3 weeks. If your near me I can bring you what you want :)
PGA2B
09-14-10, 04:05 PM
The part number from Mr Gasket is a 6367 for the 160* and 6368 for the 180*.
160*
http://www.streetsideauto.com/products.asp?PTID=3697&brand=BCZG&series=LS1+Late&partnumber=6367&Skip=True&LookupType=YMM&Reset=True
180*
http://www.streetsideauto.com/products.asp?PTID=3697&brand=BCZG&series=LS1+Late&partnumber=6368&Skip=True&LookupType=YMM&Reset=True
snzuloz
09-14-10, 05:30 PM
160*
180*
Thanks for the info!
Sent you a pm, thanks, Troy.
