: 05 V8 hard start
steveo3355
09-07-10, 08:21 PM
05 STS V8 starts hard cold about 5 sec to fire, hot about 2 sec. Have one DTC p0300 i have 45psi of fuel at cranking and no bleed off after 10min key off. The cam and crank are in sink. and has no other driveabilty problems. I am a ford master diesel tech this thing has kicked my butt.
P.S. This car has a rap sheet 2 pages long on GM dealer world lemon i think or just a GM (joke)
Thanks
Steve
EChas3
09-08-10, 12:39 AM
Intermittant crank sensor?
steveo3355
09-08-10, 08:09 PM
I have looked at cam and crank on a scope look good. Nice square wave. I is hard to start every time it is not like every 3 start it is every time. I am at a loss this car has bean to 3 dealers no luck they say the same thing i do cant find any thing wrong.
next2pool
09-08-10, 10:09 PM
Loose intake manifold bolts?
EChas3
09-09-10, 11:12 PM
OEM Plugs & wires?
steveo3355
09-09-10, 11:43 PM
Plugs and wires were done 20k ago along with the top end of the motor ie valve springs, cam, followers, intake gaskets ect..... i will check the intake bolts good thinking. I think if the intake was loose i would have a lean DTC? I have not touched gas in over 7 years first car i have had with a gas motor.
EChas3
09-10-10, 09:06 PM
Are the plugs & wires OEM? There are many reports of issues with 'better than OEM' replacements.
Fundementals still apply; fuel or fire. I'd expect a fuel mixture issue to throw diagnostic codes.
Maybe a leaky injector? Does it exhibit the issue after a short stop like refueling? If no, that supports this theory. Same deal if it's worse after longer stops.
When it does start, is there black smoke? That's unburned gas.
stevenriz
09-13-10, 08:42 AM
I am pretty handy and have a full toolbox from the body shop I used to work at. Is this something I can change myself? I haven't looked but where is the battery located? I read here and there that it may be under the back seat!
dkozloski
09-13-10, 10:32 AM
There are no plug wires. This car is COP.
SlickCityStan
09-13-10, 12:57 PM
What is COP?
next2pool
09-14-10, 11:43 AM
Coil on plug
steveo3355
10-28-10, 09:08 PM
Ok just got back to the states last week. I re-torqued the intake and it has started fine for a week. last night i hit a recap tire at 85mhp killed the front of the car 3k in damage. Thanks for the help
EChas3
10-28-10, 09:30 PM
Ouch. Are you OK?
rzambrano
10-28-10, 10:26 PM
:crying: <-----This would have been me.
You said it as if it were nothing. Anything else hurt besides the car?
steveo3355
11-02-10, 10:30 PM
I am ok car is in bad shape i will get it back Friday thank god my truck gets 8mpg i drive 85mi a day to work. I killed 60gl of diesel in a week that's 200 bucks of diesel. It is a 2002 F550 4x4 CC 6 speed 550hp 1100fpt 8mpg eeeeeeeeeee. thanks
EChas3
11-02-10, 10:47 PM
At least the car did its job by protecting you. Sorry for your loss but cars can be replaced.
