: 05 sts sunroof wont close... Please help!!!!!!
09-06-10, 07:51 PM
I checked the fuse box under the rear seat fuse is fine. Any suggestions?
09-06-10, 09:20 PM
Not enough info. Do you hear any motor running or any clicks? is it 100% open or what?
09-07-10, 12:18 AM
I do hear a clicking sound. It cooled off a bit and it closed 75% of the way
09-07-10, 12:56 AM
I had this happen, took the dealer about an hour to reset it on the track and then it closed fine... no problems since, just stop trying to get it closed on your own and have them do it becuase you could cause damage like I did. this must be a common issue with these
09-07-10, 11:34 AM
How much did they charge?
09-07-10, 12:21 PM
I took the switch panel out and pressed the button and it closed fine.......... maybe there is a loose wire?
