: 1968 472 4BBL carburetor
Dirtywaterdiver
09-02-10, 10:51 PM
Does anyone know where to get the carburetor metal shim? Part number, supplier, back alley with shady carb part dealer?
csbuckn
09-02-10, 11:27 PM
Not sure what shim your talking about.
albymangled
09-03-10, 12:02 AM
OK...I had to go back thru some of my old posts to find this ....
hope it helps ya out....
the stainless gasket / shim / spacer.....
http://img213.imageshack.us/img213/2074/shim14bi.th.jpg
could the line on this page marked "G796 (Stainless Steel
Gasket 1/16" Thick)" be what you're looking for?
http://www.carburetion.com/Quads/r4base.asp
or you might like to read page 24 of this document
http://www.walkerproducts.com/_pdf/rochester4barrel.pdf
I hope this info is of some use to you.
Alby M.
Dirtywaterdiver
09-03-10, 10:46 AM
Thanks
Dirtywaterdiver
09-06-10, 09:52 AM
Does that shim go aganst the Carb or the manifold?
shabazz18
11-01-12, 03:14 PM
I just found this. Part number 1486573
http://motors.shop.ebay.com/i.html?_nkw=1486573&_sacat=6028&_odkw=baffle+plate&_osacat=6028&bkBtn=&_trksid=m270
(http://motors.shop.ebay.com/i.html?_nkw=1486573&_sacat=6028&_odkw=baffle+plate&_osacat=6028&bkBtn=&_trksid=m270)Also my shop manual shows a gasket under the baffle plate. Then I assume an insulator gasket on top of that. This is the ONLY source I've found for these. I've been looking for a while and just found the PN.
I just read the manual, and it say gasket on top of manifold, shim on top gasket, and carburetor on top of that. So that's how it came from the factory anyway. I know this is an old thread, but hopefully this will help somebody like me in the future
steelybill
11-01-12, 07:53 PM
I had a car with one of those shim/gaskets years ago. I seem to remember that it blocked off a passage or opening in the carb base....
Dirtywaterdiver
11-02-12, 06:07 AM
Found one a while ago. 9 bucks
http://quadrajetparts.com/rochester-quadrajet-parts-quadrajet-gaskets-quadrajet-base-gaskets-quadrajet-stainless-steel-heat-shield-020-thick-p-97.html?osCsid=06c17918f8d3c3b8fde75361f760fe53
FNLCUT
11-05-12, 06:22 PM
Caddy Daddy
http://www.caddydaddy.com/Base-Plate-Shims-Gaskets-c574/
