: Hard brakes with low pedal ??
08-26-10, 06:23 PM
Hi readers of the Caddy forum!
Car : 1969 Deville 472 engine, Front disc brakes.
Problem : Low brake pedal and heavy pressure require to operate full braking.
What would you check or replace with these symptoms?
Kind regards
08-26-10, 09:37 PM
Sounds like your brake booster has died. Check/replace the vacuum line running to the booster,and if that does not repair the problem, replace the booster.
