View Full Version : bolt pattern on 78 coupe deville
gornati
08-25-10, 08:01 AM
quick and easy ...
5x115 or 5x120?
csbuckn
08-25-10, 08:48 AM
5x5, 5x127
gornati
08-25-10, 09:02 AM
5x127? really?
gornati
08-25-10, 09:06 AM
dumb... 1 in. = 2.54cm, 5 in. = 5 x 2.54cm = 12.7cm...
csbuckn
08-25-10, 09:21 AM
yep, 127mm. Are you finding out how hard it is to get rims?
sven914
08-25-10, 02:44 PM
If you need new OE rims, every Cadillac RWD has the same bolt patern. Even Ford rims will bolt on.
brougham
08-25-10, 08:03 PM
Most RWD Ford Rims are 4.5".
sven914
08-25-10, 08:15 PM
^Most maybe, but some of the ones used on the large Lincolns and Ford sedans match the GM bolt pattern. I use a Ford rim for a full spare.
jayoldschool
08-25-10, 11:03 PM
70s full size Ford and Lincoln use 5x5. Some GM hubcaps will not fit, however.
brougham
08-26-10, 12:37 AM
Ones from the last 30 years or so are the 4.5" and by now thats what's more common to find.
gornati
08-26-10, 08:33 AM
thanks you all for the quick replys..
